주요 콘텐츠로 건너뛰기
2006 Toyota Tacoma Signal Lights Replacement
필요한 것
  1. 2006 Toyota Tacoma Signal Lights Replacement, Signal Lights: 1 단계, 이미지 1/2 2006 Toyota Tacoma Signal Lights Replacement, Signal Lights: 1 단계, 이미지 2/2
    • Turn on the car, and switch the signal light ignition, so that both lights turn on.
  2. 2006 Toyota Tacoma Signal Lights Replacement: 2 단계, 이미지 1/3 2006 Toyota Tacoma Signal Lights Replacement: 2 단계, 이미지 2/3 2006 Toyota Tacoma Signal Lights Replacement: 2 단계, 이미지 3/3
    • Turn on your car, and check the signal lights on the rear end of the car.
    • Identify which side stopped blinking and/or burnt out (left side or right side).
  3. 2006 Toyota Tacoma Signal Lights Replacement: 3 단계, 이미지 1/2 2006 Toyota Tacoma Signal Lights Replacement: 3 단계, 이미지 2/2
    • Find a new replacement signal bulb according to the side where the light needs to be replaced.
    • Use the car model, make and year to find the light that best suits the car.
  4. 2006 Toyota Tacoma Signal Lights Replacement: 4 단계, 이미지 1/1
    • Prepare to remove the old turn signal.
    • Open the hood of the lens.
  5. 2006 Toyota Tacoma Signal Lights Replacement: 5 단계, 이미지 1/2 2006 Toyota Tacoma Signal Lights Replacement: 5 단계, 이미지 2/2
    • If needed, use a screwdriver to remove hood.
  6. 2006 Toyota Tacoma Signal Lights Replacement: 6 단계, 이미지 1/3 2006 Toyota Tacoma Signal Lights Replacement: 6 단계, 이미지 2/3 2006 Toyota Tacoma Signal Lights Replacement: 6 단계, 이미지 3/3
    • Remove the light bulb casing.
  7. 2006 Toyota Tacoma Signal Lights Replacement: 7 단계, 이미지 1/3 2006 Toyota Tacoma Signal Lights Replacement: 7 단계, 이미지 2/3 2006 Toyota Tacoma Signal Lights Replacement: 7 단계, 이미지 3/3
    • If needed, replace the electric connector with a new one, aligning and screwing the replacement in the same place.
    • Push the locking and turn it counterclockwise to unscrew the bulb.
  8. 2006 Toyota Tacoma Signal Lights Replacement: 8 단계, 이미지 1/2 2006 Toyota Tacoma Signal Lights Replacement: 8 단계, 이미지 2/2
    • Replace the bulb with the new one.
    • Insert the new bulb. Align the pins on the bulb with the ones inside of the car.
  9. 2006 Toyota Tacoma Signal Lights Replacement: 9 단계, 이미지 1/3 2006 Toyota Tacoma Signal Lights Replacement: 9 단계, 이미지 2/3 2006 Toyota Tacoma Signal Lights Replacement: 9 단계, 이미지 3/3
    • Place the new bulb back on the designated place.
    • Replace the hood/lens back on the car.
    • Turn the ignition switch on and engage the blinker lever (first step) to ensure proper instalment.
결론
Sofía Galán
회원 가입일: 09/27/21
181 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 20
전체 시간: 585
