주요 콘텐츠로 건너뛰기
2006 Toyota Tundra Side Mirror Replacement
필요한 것
  1. 2006 Toyota Tundra Side Mirror Replacement, Side Mirror: 1 단계, 이미지 1/3 2006 Toyota Tundra Side Mirror Replacement, Side Mirror: 1 단계, 이미지 2/3 2006 Toyota Tundra Side Mirror Replacement, Side Mirror: 1 단계, 이미지 3/3
    • Remove the plastic piece covering from the mirror bolts.
    • Place the flat head screwdriver behind the plastic covering for leverage.
    • Pop off the plastic piece to uncover all the hidden bolts.
  2. 2006 Toyota Tundra Side Mirror Replacement: 2 단계, 이미지 1/3 2006 Toyota Tundra Side Mirror Replacement: 2 단계, 이미지 2/3 2006 Toyota Tundra Side Mirror Replacement: 2 단계, 이미지 3/3
    • Remove the first bolt.
    • Use the 10mm wrench to loosen the three bolts.
    • Loosen the bolts to the end but do not take the bolts off completely.
  3. 2006 Toyota Tundra Side Mirror Replacement: 3 단계, 이미지 1/3 2006 Toyota Tundra Side Mirror Replacement: 3 단계, 이미지 2/3 2006 Toyota Tundra Side Mirror Replacement: 3 단계, 이미지 3/3
    • Remove the bolts by hand.
    • Place all the bolts in a secure location such as your pocket.
  4. 2006 Toyota Tundra Side Mirror Replacement: 4 단계, 이미지 1/2 2006 Toyota Tundra Side Mirror Replacement: 4 단계, 이미지 2/2
    • Once all the bolts are off, approach the other plastic mirror covering from the outside door.
    • Slowly pop off the plastic covering using your hands.
    • This process should be almost effortless to remove the piece.
  5. 2006 Toyota Tundra Side Mirror Replacement: 5 단계, 이미지 1/3 2006 Toyota Tundra Side Mirror Replacement: 5 단계, 이미지 2/3 2006 Toyota Tundra Side Mirror Replacement: 5 단계, 이미지 3/3
    • Once the mirror is off, push the plastic covering back on.
    • Pinch the plastic covering from both sides with one hand to make sure it is in place.
    • Make sure to keep your window rolled down for this step.
  6. 2006 Toyota Tundra Side Mirror Replacement: 6 단계, 이미지 1/3 2006 Toyota Tundra Side Mirror Replacement: 6 단계, 이미지 2/3 2006 Toyota Tundra Side Mirror Replacement: 6 단계, 이미지 3/3
    • Grab the bolts that were taken off on the second step and with your hands tighten the bolts as much as possible.
    • Repeat this step for all three bolts.
  7. 2006 Toyota Tundra Side Mirror Replacement: 7 단계, 이미지 1/3 2006 Toyota Tundra Side Mirror Replacement: 7 단계, 이미지 2/3 2006 Toyota Tundra Side Mirror Replacement: 7 단계, 이미지 3/3
    • Grab the 10mm wrench and tighten the bolts till they cannot anymore.
  8. 2006 Toyota Tundra Side Mirror Replacement: 8 단계, 이미지 1/3 2006 Toyota Tundra Side Mirror Replacement: 8 단계, 이미지 2/3 2006 Toyota Tundra Side Mirror Replacement: 8 단계, 이미지 3/3
    • From the first step, grab the first plastic covering that was taken off.
    • Align the piece with all three bolts (it should fit just like a puzzle piece).
    • Snap your plastic piece back in and give it a nice hit to make sure it is locked in till you hear a snap.
결론
Milos Skrbic
회원 가입일: 10/05/21
157 평판
안내서 1개 작성함
CSU Los Angeles, Team 11-26, Grodsky Fall 2021 CSU Los Angeles, Team 11-26, Grodsky Fall 2021 회원
CSULA-GRODSKY-F21S11G26
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 25
전체 시간: 893
