주요 콘텐츠로 건너뛰기
2007-2013 BMW X5 E70 Cabin Air Filter Replacement
필요한 것
  1. 2007-2013 BMW X5 E70 Cabin Air Filter Replacement, Cabin Air Filter: 1 단계, 이미지 1/3 2007-2013 BMW X5 E70 Cabin Air Filter Replacement, Cabin Air Filter: 1 단계, 이미지 2/3 2007-2013 BMW X5 E70 Cabin Air Filter Replacement, Cabin Air Filter: 1 단계, 이미지 3/3
    • Pop and lift the hood by pulling the release lever below the driver's seat.
    • The plastic filter cover is located on the upper left corner of the engine bay.
  2. 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: 2 단계, 이미지 1/3 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: 2 단계, 이미지 2/3 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: 2 단계, 이미지 3/3
    • There are four plastic screws on the air filter cover.
    • Twist each of the plastic screws with the half inch screw driver a quarter turn counter-clockwise。
    • Mind the plastic hood support while removing the plastic cover toward the right hand side.
  3. 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: 3 단계, 이미지 1/3 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: 3 단계, 이미지 2/3 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: 3 단계, 이미지 3/3
    • Once plastic cover has been removed, cabin air filter cover will be exposed.
    • There are three 1/2" plastic bolts.
    • Unscrew each plastic bolt by turning a quarter turn counter clockwise.
  4. 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: 4 단계, 이미지 1/3 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: 4 단계, 이미지 2/3 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: 4 단계, 이미지 3/3
    • Remove the electronic plastic connector before removing air filter cover.
    • Remove the air filter cover from the vehicle.
  5. 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: 5 단계, 이미지 1/3 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: 5 단계, 이미지 2/3 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: 5 단계, 이미지 3/3
    • Once the filter cover has been removed two air cabin filters will be exposed.
    • Locate the plastic clips on each end of the filter holder
    • Depress the clips using your thumbs to remove the air filter.
  6. 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: 6 단계, 이미지 1/3 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: 6 단계, 이미지 2/3 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: 6 단계, 이미지 3/3
    • Pay attention to Air Flow indicator arrows when reinstalling the filters.
    • Clip the filters back into place one side at a time.
    • Repeat the process for the second filter.
  7. 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: 7 단계, 이미지 1/3 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: 7 단계, 이미지 2/3 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: 7 단계, 이미지 3/3
    • Reinstall the filter cover.
    • Re-connect the plastic electronic plug.
  8. 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: 8 단계, 이미지 1/3 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: 8 단계, 이미지 2/3 2007-2013 BMW X5 E70 Cabin Air Filter Replacement: 8 단계, 이미지 3/3
    • Re-install the plastic cover.
    • Mind the hydraulic lift for the hood while re-installing plastic cover.
    • Clean dust off the cover for good measure.
결론
To reassemble your device follow these instructions in reverse order.
다른 6명이 해당 안내서를 완성하였습니다.
Patrick Whitmire
회원 가입일: 04/28/17
227 평판
안내서 1개 작성함
UC Davis, Team S4-G3, Cole Spring 2017 UC Davis, Team S4-G3, Cole Spring 2017 회원
UCD-COLE-S17S4G3
3 회원들
안내서 1개 작성하였습니다
댓글 한 개
This is not a cabin filter lol
E70/E71 have an actual cabin filter under the glove box.
lifeoftech - 답글
댓글 쓰기
조회 통계:
24 시간 전: 12
7일 전: 51
30일 전: 205
전체 시간: 14,795
