주요 콘텐츠로 건너뛰기
2007-2013 Toyota Tundra Charging Port Replacement
필요한 것
  1. 2007-2013 Toyota Tundra Charging Port Replacement, Charging Port: 1 단계, 이미지 2개 중 1개 2007-2013 Toyota Tundra Charging Port Replacement, Charging Port: 1 단계, 이미지 2개 중 2개
    • Remove the switch cover on the left side of the radio by turning it to the "2WD" mode and pulling it straight out.
  2. 2007-2013 Toyota Tundra Charging Port Replacement: 2 단계, 이미지 1개 중 1개
    • Use the plastic pry tool to separate the part of the dashboard behind the steering wheel from the rest of the vehicle.
    • Disconnect the connectors between the panel and the rest of the dashboard.
  3. 2007-2013 Toyota Tundra Charging Port Replacement: 3 단계, 이미지 2개 중 1개 2007-2013 Toyota Tundra Charging Port Replacement: 3 단계, 이미지 2개 중 2개
    • Use your hand to pull out the furthest panel under the radio.
  4. 2007-2013 Toyota Tundra Charging Port Replacement: 4 단계, 이미지 2개 중 1개 2007-2013 Toyota Tundra Charging Port Replacement: 4 단계, 이미지 2개 중 2개
    • Disconnect the wires on the auxiliary power outlets and set the panel aside.
    • You may have to wiggle the connector to get it loose enough to pull it off.
  5. 2007-2013 Toyota Tundra Charging Port Replacement: 5 단계, 이미지 2개 중 1개 2007-2013 Toyota Tundra Charging Port Replacement: 5 단계, 이미지 2개 중 2개
    • Use your hand to pull out the panel directly under the radio.
  6. 2007-2013 Toyota Tundra Charging Port Replacement: 6 단계, 이미지 3개 중 1개 2007-2013 Toyota Tundra Charging Port Replacement: 6 단계, 이미지 3개 중 2개 2007-2013 Toyota Tundra Charging Port Replacement: 6 단계, 이미지 3개 중 3개
    • Use the pry tool to push in the tab on the top from behind and remove the charging port.
    • The tab will be very stiff. It is necessary to use a decent amount of force.
  7. 2007-2013 Toyota Tundra Charging Port Replacement: 7 단계, 이미지 1개 중 1개
    • Disconnect the wires from the rest of the vehicle by pushing in all of the tabs simultaneously and pulling them apart.
    • In reassembly, first feed the wire through the slot of the charging port.
  8. 2007-2013 Toyota Tundra Charging Port Replacement: 8 단계, 이미지 2개 중 1개 2007-2013 Toyota Tundra Charging Port Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the cloth surrounding the wires on the old charging port.
    • Cut the wires near the base of the old charging port.
  9. 2007-2013 Toyota Tundra Charging Port Replacement: 9 단계, 이미지 3개 중 1개 2007-2013 Toyota Tundra Charging Port Replacement: 9 단계, 이미지 3개 중 2개 2007-2013 Toyota Tundra Charging Port Replacement: 9 단계, 이미지 3개 중 3개
    • Use a wire stripper to strip the cover from the ends of all of the wires.
    • Twist the same colored wires and put heat shrink over them.
  10. 2007-2013 Toyota Tundra Charging Port Replacement: 10 단계, 이미지 2개 중 1개 2007-2013 Toyota Tundra Charging Port Replacement: 10 단계, 이미지 2개 중 2개
    • Take some thin heat shrink, cut it in half and put one half on each of the new wires.
  11. 2007-2013 Toyota Tundra Charging Port Replacement: 11 단계, 이미지 1개 중 1개
    • Twist the old and new corresponding wires together securely.
  12. 2007-2013 Toyota Tundra Charging Port Replacement: 12 단계, 이미지 1개 중 1개
    • Solder the old and new wires together so that the black wires are soldered together and the red wires are soldered together.
    • Handle the Soldering iron with caution or you could burn yourself.
  13. 2007-2013 Toyota Tundra Charging Port Replacement: 13 단계, 이미지 2개 중 1개 2007-2013 Toyota Tundra Charging Port Replacement: 13 단계, 이미지 2개 중 2개
    • Put the small heat shrink over the exposed wire and warm it with the heat gun so that it cinches the wires.
    • Do the same with the larger heat shrink.
결론
작성자
1다른 기여자 명과 함께
Ryan
회원 가입일: 09/21/23
217 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 43
전체 시간: 907
