주요 콘텐츠로 건너뛰기
2007-2012 Acura RDX Engine Air Filter Replacement
필요한 것
  1. 2007-2012 Acura RDX Engine Air Filter Replacement, Engine Air Filter: 1 단계, 이미지 1/1
    • On the driver-side footwell, pull the latch to open the hood.
    • Make sure you leave time between driving and performing this fix. Working around the engine while it is still hot presents a burn risk!
  2. 2007-2012 Acura RDX Engine Air Filter Replacement: 2 단계, 이미지 1/1
    • Lift up the second latch to fully open the hood.
    • This one is located right above the Acura logo on the front of the car.
  3. 2007-2012 Acura RDX Engine Air Filter Replacement: 3 단계, 이미지 1/1
    • The airbox is directly behind the battery. Remove the four 9 mm bolts holding the airbox down.
    • If you ever had the bolts replaced, they may have a slightly different head diameter. If a 9 mm socket doesn't fit, use the appropriate size socket.
  4. 2007-2012 Acura RDX Engine Air Filter Replacement: 4 단계, 이미지 1/1
    • Unscrew each of the bolts. Do not remove the bolts.
    • If the bolts are stuck, use some WD-40 or similar lubricant to help loosen them.
  5. 2007-2012 Acura RDX Engine Air Filter Replacement: 5 단계, 이미지 1/2 2007-2012 Acura RDX Engine Air Filter Replacement: 5 단계, 이미지 2/2
    • Remove the air filter from the vehicle.
    • In many cases, air filters will have an arrow to show the direction they should go. This direction represents the airflow, for this particular car we want that facing upwards.
    • Do not fully remove the bolts.
결론
One the task is done, close the hood and you are good to drive!
다른 한 분이 해당 안내서를 완성하였습니다.
Andrew Graham
회원 가입일: 03/23/21
145 평판
안내서 1개 작성함
UMass Dartmouth, Team S2-G6, Riel Spring 2021 UMass Dartmouth, Team S2-G6, Riel Spring 2021 회원
UMASSD-RIEL-S21S2G6
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 11
30일 전: 47
전체 시간: 1,534
