주요 콘텐츠로 건너뛰기
2007-2012 Jeep Wrangler Headlight Replacement
필요한 것
  1. 2007-2012 Jeep Wrangler Headlight Replacement, Headlight: 1 단계, 이미지 1/2 2007-2012 Jeep Wrangler Headlight Replacement, Headlight: 1 단계, 이미지 2/2
    • Locate the two gray latches on either side of the hood near the headlights.
    • Pull the latches away from the hood to release the latches.
  2. 2007-2012 Jeep Wrangler Headlight Replacement: 2 단계, 이미지 1/2 2007-2012 Jeep Wrangler Headlight Replacement: 2 단계, 이미지 2/2
    • Reach under the hood and push the lever left to right. You should now be able to lift the hood.
    • Prop open the hood by inserting the support rod into the designated hole on the underside of the hood.
  3. 2007-2012 Jeep Wrangler Headlight Replacement: 3 단계, 이미지 1/3 2007-2012 Jeep Wrangler Headlight Replacement: 3 단계, 이미지 2/3 2007-2012 Jeep Wrangler Headlight Replacement: 3 단계, 이미지 3/3
    • Locate all six push on fasteners on the top of the grill.
    • Use a flathead screwdriver to pry up the fasteners, and make sure you put the screws somewhere safe.
    • If the fasteners will not come up, use two flathead screwdrivers on either side of the fastener to remove.
  4. 2007-2012 Jeep Wrangler Headlight Replacement: 4 단계, 이미지 1/3 2007-2012 Jeep Wrangler Headlight Replacement: 4 단계, 이미지 2/3 2007-2012 Jeep Wrangler Headlight Replacement: 4 단계, 이미지 3/3
    • Locate right and left blinker lights under the fenders.
    • Twist blinker light toward the ground, and make sure you pull the bulb out carefully.
    • Make sure you are handling bulb carefully.
  5. 2007-2012 Jeep Wrangler Headlight Replacement: 5 단계, 이미지 1/3 2007-2012 Jeep Wrangler Headlight Replacement: 5 단계, 이미지 2/3 2007-2012 Jeep Wrangler Headlight Replacement: 5 단계, 이미지 3/3
    • Make sure all fasteners are removed from top of the grill, and the top of the grill is loose.
    • Firmly pull the bottom of the grill until the grill disconnects from the jeep.
  6. 2007-2012 Jeep Wrangler Headlight Replacement: 6 단계, 이미지 1/2 2007-2012 Jeep Wrangler Headlight Replacement: 6 단계, 이미지 2/2
    • Locate the 4 screws holding the headlight in place.
    • Use a star bit screwdriver to unscrew the .164-18 x .625 mm star bit screws around the headlight, and make sure you place screws somewhere safe.
    • Hold the headlight when unscrewing last screw to prevent the headlight from falling.
  7. 2007-2012 Jeep Wrangler Headlight Replacement: 7 단계, 이미지 1/2 2007-2012 Jeep Wrangler Headlight Replacement: 7 단계, 이미지 2/2
    • Use your hands to carefully remove silver ring from the headlight.
  8. 2007-2012 Jeep Wrangler Headlight Replacement: 8 단계, 이미지 1/3 2007-2012 Jeep Wrangler Headlight Replacement: 8 단계, 이미지 2/3 2007-2012 Jeep Wrangler Headlight Replacement: 8 단계, 이미지 3/3
    • Locate red tab on the headlight plug connector, and push it away from the headlight.
    • Firmly pull the connector away from headlight to remove.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Marco Santini
회원 가입일: 09/29/15
290 평판
안내서 1개 작성함
Cal Poly, Team 17-3, Green Fall 2015 Cal Poly, Team 17-3, Green Fall 2015 회원
CPSU-GREEN-F15S17G3
4 회원들
안내서 3개 작성하였습니다
댓글 3개
Could Jeep make it more difficult to do simple maintenance? I doubt it!
Linda Procida - 답글
What is that green connector called? I’m having trouble putting new lights because none of the converters fit.
Alex - 답글
What it is the recommended torque to screw it back?
Luis Vitorio Cargnini - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 71
전체 시간: 20,448
