소개
Driving with a malfunctioning tail light is dangerous. This guide will walk you through the steps of replacing a broken tail light bulb on your 2007-2012 Jeep Wrangler so you can get back on the road quickly.
필요한 것
Determine which tail light is not working.
The tail lights are located within the red rectangles.
다른 6명이 해당 안내서를 완성하였습니다.
댓글 8개
I got that far but I cant get the bulbs out - they seem to be stuck in the sockets - any ideas? thank you very much - steven
On mine the clips actually need to be pushed out and not pinched - can stick a small screwdriver in there to push them out ( maybe one for each)
I have successfully replaced these bulbs several times. This time I decided to use an LED replacement bulb (same part number but with an XL suffix). The new bulb went in fine and works BUT the computer has not reset regarding the warning message that the right rear turn signal lamp being out. Any ideas?
I haven't had any luck. In fact, after two weeks the led bulbs always burn out. I was told you bed a diode in between the socket, and the bulb.
if the top bulb is my tail light is the bottom light my blinker
Hello! I replaced the bulb correctly but it is still not illuminating. Any ideas on troubleshooting?
