소개
This guide will show you how to replace the map lights of your sixth generation Nissan Sentra (years 2007-2012). Since each car has its own unique features, and while there are guides to fix others, this guide allows Nissan Sentra car owners to replace their car map lights without the risk of damaging the car parts or their vehicle.
When performing this guide ensure that you are in a very well lit area to aid with visibility. Before you begin, make sure the car is off and in park.
If you suspect that your map lights are out, turn them on and off a few times prior to the replacement, however, if you turned your map lights on to test them prior to beginning this guide, wait a few minutes before following the steps presented before you. This ensures that the bulb is cold, which prevents any burns or injuries.
필요한 것
Use a spudger or opening tool to gently pry the lens out. Begin in the small space between the lens and console.
If all goes well, your car now has new bright map lights and you will now have the knowledge to perform future map light replacements for your 2012 Nissan Sentra. If this knowledge is forgotten, our guide will help provide you with proper instructions and indications on how to replace your map lights again. If you know of anyone with this model of car, and they need a replacement of their map lights, send this guide their way in order to assist them in the process of replacing their map lights. Like iFixit says, "if you can't fix it, you don't own it."
다른 한 분이 해당 안내서를 완성하였습니다.
