주요 콘텐츠로 건너뛰기
2007 Chevy Aveo Indicator light bulb Replacement
필요한 것
  1. 2007 Chevy Aveo Indicator light bulb Replacement, Indicator light bulb: 1 단계, 이미지 1/3 2007 Chevy Aveo Indicator light bulb Replacement, Indicator light bulb: 1 단계, 이미지 2/3 2007 Chevy Aveo Indicator light bulb Replacement, Indicator light bulb: 1 단계, 이미지 3/3
    • Here is a view of the left tail light assembly
    • Open the rear hatch,( or trunk if it is a sedan). On the inside of the assembly are two retaining screws. Remove those
    • both screws are #6x3/4 inch
  2. 2007 Chevy Aveo Indicator light bulb Replacement: 2 단계, 이미지 1/3 2007 Chevy Aveo Indicator light bulb Replacement: 2 단계, 이미지 2/3 2007 Chevy Aveo Indicator light bulb Replacement: 2 단계, 이미지 3/3
    • Here is a view of the assembly with the screws removed.
    • Insert some sort of prying tool between the tail light assembly and the body, just below the crease in the body and pry to the rear of the vehicle. a snap will be felt/heard as the plastic stud releases
    • Move the prying tool to above 1 1/2 inch above the bottom of the assembly. Insert it between the assembly and body and gently pry toward the rear of the vehicle. This should free the second stud.
  3. 2007 Chevy Aveo Indicator light bulb Replacement: 3 단계, 이미지 1/3 2007 Chevy Aveo Indicator light bulb Replacement: 3 단계, 이미지 2/3 2007 Chevy Aveo Indicator light bulb Replacement: 3 단계, 이미지 3/3
    • Now just pull the assembly straight back.
    • Avoid pulling the assembly to one side or another, that can snap the plastic studs
    • Locate the burned out bulb. In this case it was the indicator light. Rotate the bulb sockets in a counterclockwise direction.
    • Pull the sockets straight out of the tail light assembly.
결론
다른 7명이 해당 안내서를 완성하였습니다.
oldturkey03
회원 가입일: 09/29/10
778,195 평판
안내서 118개 작성하였습니다
Global Fixers Global Fixers 회원
Community
31 회원들
안내서 520개 작성하였습니다
댓글 2개
This was a great help thank you!!
Jeffrey Blum - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 40
전체 시간: 9,611
