주요 콘텐츠로 건너뛰기
2007 Honda Accord Tail Light Replacement
필요한 것
  1. 2007 Honda Accord Tail Light Replacement, Tail Light: 1 단계, 이미지 1/3 2007 Honda Accord Tail Light Replacement, Tail Light: 1 단계, 이미지 2/3 2007 Honda Accord Tail Light Replacement, Tail Light: 1 단계, 이미지 3/3
    • Open the trunk.
    • Remove the two screws from the tail light area in the trunk using a Torx screwdriver.
  2. 2007 Honda Accord Tail Light Replacement: 2 단계, 이미지 1/2 2007 Honda Accord Tail Light Replacement: 2 단계, 이미지 2/2
    • Pull back the trunk covering.
  3. 2007 Honda Accord Tail Light Replacement: 3 단계, 이미지 1/3 2007 Honda Accord Tail Light Replacement: 3 단계, 이미지 2/3 2007 Honda Accord Tail Light Replacement: 3 단계, 이미지 3/3
    • Pull on the gray plastic part of the tail light assembly to remove it from the car.
  4. 2007 Honda Accord Tail Light Replacement: 4 단계, 이미지 1/1
    • Unscrew the bulb from its socket and replace it with a new one.
  5. 2007 Honda Accord Tail Light Replacement: 5 단계, 이미지 1/3 2007 Honda Accord Tail Light Replacement: 5 단계, 이미지 2/3 2007 Honda Accord Tail Light Replacement: 5 단계, 이미지 3/3
    • Put the tail light assembly back in the car.
    • Replace the trunk covering.
    • Screw the trunk covering screws back in place using a Torx screwdriver.
결승점
Darien Howard
회원 가입일: 02/14/21
121 평판
안내서 1개 작성함
Texas Tech, Team S3-G8, Cowan Spring 2021 Texas Tech, Team S3-G8, Cowan Spring 2021 회원
TTU-COWAN-S21S3G8
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 72
전체 시간: 3,096
