주요 콘텐츠로 건너뛰기
2008-2013 Subaru Forester Cabin Air Filter Replacement
필요한 것
  1. 2008-2013 Subaru Forester Cabin Air Filter Replacement, Cabin Air Filter: 1 단계, 이미지 1/1
    • Ensure the vehicle is shut off with the key removed from the ignition before you begin.
    • Open the glovebox located on the passenger side.
  2. 2008-2013 Subaru Forester Cabin Air Filter Replacement: 2 단계, 이미지 1/2 2008-2013 Subaru Forester Cabin Air Filter Replacement: 2 단계, 이미지 2/2
    • Unhook the glovebox retention arm from the side of the glovebox by squeezing the clip together with your fingertips, and prying the arm off the lower connection point only.
    • Gently push the arm up and half way in to prevent accidental breakage.
  3. 2008-2013 Subaru Forester Cabin Air Filter Replacement: 3 단계, 이미지 1/2 2008-2013 Subaru Forester Cabin Air Filter Replacement: 3 단계, 이미지 2/2
    • Starting on either the left or right side, insert screwdriver blade tip into the small catch ramp until it releases.
    • Repeat inserting screwdriver blade tip on opposite side of glovebox and catch ramp until both sides are released and glovebox falls freely open.
  4. 2008-2013 Subaru Forester Cabin Air Filter Replacement: 4 단계, 이미지 1/2 2008-2013 Subaru Forester Cabin Air Filter Replacement: 4 단계, 이미지 2/2
    • Remove the glovebox by pulling horizontally away from its (C shaped) hinge points.
  5. 2008-2013 Subaru Forester Cabin Air Filter Replacement: 5 단계, 이미지 1/3 2008-2013 Subaru Forester Cabin Air Filter Replacement: 5 단계, 이미지 2/3 2008-2013 Subaru Forester Cabin Air Filter Replacement: 5 단계, 이미지 3/3
    • Open door to filter compartment to access filter.
    • Remove filter media.
    • Note orientation of filter for reinsertion.
결론
Finally, to reinstall the clean cabin air filter, simply follow these same instructions, but in reverse order.
Purchasing and replacing your own cabin filter is simple, time-saving, and resourceful. Congratulations on a job well done!
다른 3명이 해당 안내서를 완성하였습니다.
Sean Mc
회원 가입일: 09/26/18
175 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 33
30일 전: 94
전체 시간: 6,739
