주요 콘텐츠로 건너뛰기
2008-2013 Volkswagen Golf Tail Light Bulb Replacement
필요한 것
  1. 2008-2013 Volkswagen Golf Tail Light Bulb Replacement, Locate tail light compartment: 1 단계, 이미지 1/1
    • On the driver's side of the vehicle's rear cargo area, locate the rectangular tail light compartment cover.
  2. 2008-2013 Volkswagen Golf Tail Light Bulb Replacement, Remove cover: 2 단계, 이미지 1/1
    • Using your fingers, gently pull the cover away from the compartment.
  3. 2008-2013 Volkswagen Golf Tail Light Bulb Replacement, Locate the light bulb assembly: 3 단계, 이미지 1/1
    • With the cover removed, locate the light bulb assembly.
    • Use a flathead screwdriver to release the locking tab.
  4. 2008-2013 Volkswagen Golf Tail Light Bulb Replacement, Remove the light bulb assembly: 4 단계, 이미지 1/1
    • Pull gently to remove the light bulb assembly.
    • The assembly will remain connected to the vehicle via the wiring harness.
  5. 2008-2013 Volkswagen Golf Tail Light Bulb Replacement, Locate the light bulb: 5 단계, 이미지 1/1
    • Turn the assembly so that the smaller tail light bulb and larger fog light bulb are visible.
  6. 2008-2013 Volkswagen Golf Tail Light Bulb Replacement, Remove the tail light bulb: 6 단계, 이미지 1/1
    • Using your fingers, gently pull the tail light bulb out of the socket.
    • Insert a new replacement light bulb into the tail light socket.
    • Excess force may cause light bulbs to break.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Jeffrey Jacquin
회원 가입일: 10/11/14
311 평판
안내서 1개 작성함
USF Tampa, Team 1-12, Donnelly Fall 2014 USF Tampa, Team 1-12, Donnelly Fall 2014 회원
USFT-DONNELLY-F14S1G12
1 회원
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 14
7일 전: 91
30일 전: 395
전체 시간: 47,535
