주요 콘텐츠로 건너뛰기
2008-2012 Ford Escape Air Filter Replacement
필요한 것
  1. 2008-2012 Ford Escape Air Filter Replacement, 2010 Ford Escape air filter: 1 단계, 이미지 1/3 2008-2012 Ford Escape Air Filter Replacement, 2010 Ford Escape air filter: 1 단계, 이미지 2/3 2008-2012 Ford Escape Air Filter Replacement, 2010 Ford Escape air filter: 1 단계, 이미지 3/3
    • Pull the open hood tab found under the dash by the foot pedals.
    • When hood is opened, locate the air filter compartment, circled above.
  2. 2008-2012 Ford Escape Air Filter Replacement: 2 단계, 이미지 1/2 2008-2012 Ford Escape Air Filter Replacement: 2 단계, 이미지 2/2
    • Unlatch all four latches.
  3. 2008-2012 Ford Escape Air Filter Replacement: 3 단계, 이미지 1/2 2008-2012 Ford Escape Air Filter Replacement: 3 단계, 이미지 2/2
    • Remove the cover of the air filter compartment , exposing the air filter.
  4. 2008-2012 Ford Escape Air Filter Replacement: 4 단계, 이미지 1/2 2008-2012 Ford Escape Air Filter Replacement: 4 단계, 이미지 2/2
    • Take out the air filter, by lifting up and to the left.
  5. 2008-2012 Ford Escape Air Filter Replacement: 5 단계, 이미지 1/1
    • Align the circular bump in the air filter compartment to the circle on the air filter itself.
    • Push down and to the right to insert the new air filter.
  6. 2008-2012 Ford Escape Air Filter Replacement: 6 단계, 이미지 1/2 2008-2012 Ford Escape Air Filter Replacement: 6 단계, 이미지 2/2
    • Put the cover back on the air filter compartment.
    • Latch the cover shut.
결승점
Emily Davidson
회원 가입일: 04/15/20
133 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 38
30일 전: 119
전체 시간: 3,149
