주요 콘텐츠로 건너뛰기
2008-2012 Honda Accord Interior Lights Replacement
필요한 것
  1. 2008-2012 Honda Accord Interior Lights Replacement, Interior Light: 1 단계, 이미지 1/2 2008-2012 Honda Accord Interior Lights Replacement, Interior Light: 1 단계, 이미지 2/2
    • Acquire replacement car dome light and a 1/4" flathead screwdriver.
  2. 2008-2012 Honda Accord Interior Lights Replacement: 2 단계, 이미지 1/2 2008-2012 Honda Accord Interior Lights Replacement: 2 단계, 이미지 2/2
    • Identify the broken light(s). Turn the light switch on and off to find the broken light.
  3. 2008-2012 Honda Accord Interior Lights Replacement: 3 단계, 이미지 1/2 2008-2012 Honda Accord Interior Lights Replacement: 3 단계, 이미지 2/2
    • Use the screwdriver to carefully remove the plastic cover.
    • Insert the screwdriver between the light cover and plastic sides and slowly move the screwdriver back and forth until the light cover becomes loose.
  4. 2008-2012 Honda Accord Interior Lights Replacement: 4 단계, 이미지 1/2 2008-2012 Honda Accord Interior Lights Replacement: 4 단계, 이미지 2/2
    • Turn the car off and wait until the light is cooled down before removal.
    • Use the flathead to help remove the light. Position the screwdriver between one end of the light and terminal.
    • Gently move the screwdriver downwards until the interior light detaches from the battery terminals.
  5. 2008-2012 Honda Accord Interior Lights Replacement: 5 단계, 이미지 1/1
    • Slide one end of the replacement light against one terminal and push down delicately until the light is secure in place.
  6. 2008-2012 Honda Accord Interior Lights Replacement: 6 단계, 이미지 1/2 2008-2012 Honda Accord Interior Lights Replacement: 6 단계, 이미지 2/2
    • With the clips positioned upwards, move the plastic cover towards the light. Secure the cover back to its original position by applying a small force at the ends where the clips are.
  7. 2008-2012 Honda Accord Interior Lights Replacement: 7 단계, 이미지 1/1
    • Turn on the light to verify funtionality.
    • Repeat steps 2-7 for the other light if necessary.
결론
German Martinez
회원 가입일: 10/24/23
145 평판
안내서 1개 작성함
CSU Los Angeles, Team 9-8, Ribeiro Fall 2023 CSU Los Angeles, Team 9-8, Ribeiro Fall 2023 회원
CSULA-RIBEIRO-F23S9G8
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 9
30일 전: 44
전체 시간: 329
