주요 콘텐츠로 건너뛰기
2008-2011 Saab 9-3 Reverse Light Replacement
필요한 것
  1. 2008-2011 Saab 9-3 Reverse Light Replacement, 2008-2011 Saab 9-3 Reverse Light: 1 단계, 이미지 1/2 2008-2011 Saab 9-3 Reverse Light Replacement, 2008-2011 Saab 9-3 Reverse Light: 1 단계, 이미지 2/2
    • Park your car in an area with good light.
  2. 2008-2011 Saab 9-3 Reverse Light Replacement: 2 단계, 이미지 1/3 2008-2011 Saab 9-3 Reverse Light Replacement: 2 단계, 이미지 2/3 2008-2011 Saab 9-3 Reverse Light Replacement: 2 단계, 이미지 3/3
    • Press the button on the key fob or on the front driver-side door to open the trunk of your car.
    • Make sure the trunk lid is open all of the way to avoid being hit.
  3. 2008-2011 Saab 9-3 Reverse Light Replacement: 3 단계, 이미지 1/3 2008-2011 Saab 9-3 Reverse Light Replacement: 3 단계, 이미지 2/3 2008-2011 Saab 9-3 Reverse Light Replacement: 3 단계, 이미지 3/3
    • Use a screwdriver to press down on the center of the trunk lining fasteners.
    • Remove the fasteners.
    • Any screwdriver will work, as the fasteners only needs to be pushed to release them. No screws require removal.
  4. 2008-2011 Saab 9-3 Reverse Light Replacement: 4 단계, 이미지 1/1
    • Gently pull down on the trunk lining to access the light socket.
    • You may need a second pair of hands to help hold down the lining unless all fasteners are removed. If not, the lining will naturally return to its original position.
  5. 2008-2011 Saab 9-3 Reverse Light Replacement: 5 단계, 이미지 1/2 2008-2011 Saab 9-3 Reverse Light Replacement: 5 단계, 이미지 2/2
    • Use light pressure to pull the tab on the light socket towards you.
    • Gently pull down on the light socket to remove.
  6. 2008-2011 Saab 9-3 Reverse Light Replacement: 6 단계, 이미지 1/2 2008-2011 Saab 9-3 Reverse Light Replacement: 6 단계, 이미지 2/2
    • Push down and twist the lightbulb counterclockwise to remove it.
    • Wear gloves when doing this to prevent getting oil from your fingers on the bulb.
  7. 2008-2011 Saab 9-3 Reverse Light Replacement: 7 단계, 이미지 1/1
    • Insert the replacement lightbulb by pushing down and twisting clockwise.
  8. 2008-2011 Saab 9-3 Reverse Light Replacement: 8 단계, 이미지 1/3 2008-2011 Saab 9-3 Reverse Light Replacement: 8 단계, 이미지 2/3 2008-2011 Saab 9-3 Reverse Light Replacement: 8 단계, 이미지 3/3
    • Push the light case back into place.
    • It will click into place when it is securely fastened.
  9. 2008-2011 Saab 9-3 Reverse Light Replacement: 9 단계, 이미지 1/2 2008-2011 Saab 9-3 Reverse Light Replacement: 9 단계, 이미지 2/2
    • Replace the trunk lining and fasteners.
    • Test the reverse light to make sure it's working before driving on public roads.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Adriano
회원 가입일: 01/09/24
199 평판
안내서 1개 작성함
York University, Team 2-5, O'Regan Winter 2024 York University, Team 2-5, O'Regan Winter 2024 회원
YORK-O'REGAN-W24S2G5
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 24
전체 시간: 102
