주요 콘텐츠로 건너뛰기
2008-2010 Audi A3 Sportback Key FOB Battery Replacement
필요한 것
  1. 2008-2010 Audi A3 Sportback Key FOB Battery Replacement, Key FOB Battery: 1 단계, 이미지 1/3 2008-2010 Audi A3 Sportback Key FOB Battery Replacement, Key FOB Battery: 1 단계, 이미지 2/3 2008-2010 Audi A3 Sportback Key FOB Battery Replacement, Key FOB Battery: 1 단계, 이미지 3/3
    • With the tip of a flat head screwdriver, insert it under the edge of the key fob and push against the back cover to pop it off.
    • Take caution as you apply force to open the cover as the flathead screwdriver is a sharp tool.
  2. 2008-2010 Audi A3 Sportback Key FOB Battery Replacement: 2 단계, 이미지 1/2 2008-2010 Audi A3 Sportback Key FOB Battery Replacement: 2 단계, 이미지 2/2
    • Remove the round CR2032 battery from the fob back cover with a plastic spudger or opening tool.
    • The battery has a "+" positive side (textured surface) and a "–" negative side (smooth surface).
  3. 2008-2010 Audi A3 Sportback Key FOB Battery Replacement: 3 단계, 이미지 1/1
    • Insert a new battery and pop the cover back on by hand.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Tania Fulbright
회원 가입일: 10/30/19
481 평판
안내서 3개 작성하였습니다
University of Memphis, Team S4-G4, Kim Fall 2019 University of Memphis, Team S4-G4, Kim Fall 2019 회원
UM-KIM-F19S4G4
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 24
30일 전: 178
전체 시간: 8,277
