주요 콘텐츠로 건너뛰기
2008 BMW 335xi Blower Motor Replacement
필요한 것
  1. 2008 BMW 335xi Blower Motor Replacement, Blower Motor: 1 단계, 이미지 1/3 2008 BMW 335xi Blower Motor Replacement, Blower Motor: 1 단계, 이미지 2/3 2008 BMW 335xi Blower Motor Replacement, Blower Motor: 1 단계, 이미지 3/3
    • Put the passenger seat all the way back to create as much room as possible.
    • Remove any objects from the floor of the passenger seat so that you have a clean workspace.
  2. 2008 BMW 335xi Blower Motor Replacement: 2 단계, 이미지 1/2 2008 BMW 335xi Blower Motor Replacement: 2 단계, 이미지 2/2
    • Remove the panel on the right side of the trunk to expose the battery.
    • Twist the knob to unlatch the door so that you can remove it.
  3. 2008 BMW 335xi Blower Motor Replacement: 3 단계, 이미지 1/3 2008 BMW 335xi Blower Motor Replacement: 3 단계, 이미지 2/3 2008 BMW 335xi Blower Motor Replacement: 3 단계, 이미지 3/3
    • Use a 10mm socket wrench to loosen the bolt and remove the negative battery terminal.
    • Then tuck it to the right side and wrap it in a rag.
    • This prevents the circuit from being accidentally completed while you continue working.
  4. 2008 BMW 335xi Blower Motor Replacement: 4 단계, 이미지 1/3 2008 BMW 335xi Blower Motor Replacement: 4 단계, 이미지 2/3 2008 BMW 335xi Blower Motor Replacement: 4 단계, 이미지 3/3
    • Remove the two T20 Torx screws located below the glove box.
    • One is located all the way on the right and the other one is located all the way on the left.
    • The panel will drop down as the screws are removed. Pull the panel away slightly.
    • Careful not to let it drop all the way down as a wire is connected to the footwell light.
    • Disconnect the black cable for the footwell light.
  5. 2008 BMW 335xi Blower Motor Replacement: 5 단계, 이미지 1/3 2008 BMW 335xi Blower Motor Replacement: 5 단계, 이미지 2/3 2008 BMW 335xi Blower Motor Replacement: 5 단계, 이미지 3/3
    • There is only one connecter that needs to be disconnected to remove the blower motor. This connector is black with two red/orange wires going into it.
    • Pinch the connector on the top and bottom and pull it out to remove it.
  6. 2008 BMW 335xi Blower Motor Replacement: 6 단계, 이미지 1/2 2008 BMW 335xi Blower Motor Replacement: 6 단계, 이미지 2/2
    • Pull down on the tab towards the front of the car and at the same time turn the whole assembly clockwise.
    • Pull the round black assembly out from the vehicle.
    • This is the blower motor assembly!
    • When pulling the blower motor out, be careful not to drop it on yourself.
결론
To reassemble your blower motor, follow these instructions in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
Dhimitraq Lolo
회원 가입일: 03/26/19
181 평판
안내서 1개 작성함
UMass Dartmouth, Team S3-G11, Saloman Spring 2021 UMass Dartmouth, Team S3-G11, Saloman Spring 2021 회원
UMASSD-SALOMAN-S21S3G11
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 65
전체 시간: 3,146
