주요 콘텐츠로 건너뛰기
2008 Toyota Corolla Battery Replacement
필요한 것
  1. 2008 Toyota Corolla Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 2008 Toyota Corolla Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Open the car hood.
    • The battery will be located on the bottom right.
  2. 2008 Toyota Corolla Battery Replacement: 2 단계, 이미지 2개 중 1개 2008 Toyota Corolla Battery Replacement: 2 단계, 이미지 2개 중 2개
    • There are two terminals on the battery. The positive terminal is on the left with the red cover. The negative terminal is on the right.
    • Unscrew the bolt to loosen the negative terminal.
    • Remove the negative terminal from the battery.
  3. 2008 Toyota Corolla Battery Replacement: 3 단계, 이미지 2개 중 1개 2008 Toyota Corolla Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Take the red cover off the positive terminal.
    • Unscrew the bolt to remove the positive terminal.
    • Loosening the screws of the terminal can be difficult. In the first picture, I used pliers to help loosen up the screw holding the terminal tight.
  4. 2008 Toyota Corolla Battery Replacement: 4 단계, 이미지 3개 중 1개 2008 Toyota Corolla Battery Replacement: 4 단계, 이미지 3개 중 2개 2008 Toyota Corolla Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Disconnect the battery's terminals from the battery, and remove the old battery.
    • Batteries, over time, tend to get dirty. You can mix baking soda with water and use a brush to clean your terminals.
  5. 2008 Toyota Corolla Battery Replacement: 5 단계, 이미지 3개 중 1개 2008 Toyota Corolla Battery Replacement: 5 단계, 이미지 3개 중 2개 2008 Toyota Corolla Battery Replacement: 5 단계, 이미지 3개 중 3개
    • Once everything is clean, you can begin installing your new battery.
    • Install your new battery in the correct space. You will install the negative terminal first, then the positive terminal.
    • Before moving on, make sure each screw on the terminal is tight and secured.
  6. 2008 Toyota Corolla Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Ensure that every bolt is secured.
    • Start your car and let your car run for a couple of minutes.
결승점
다른 4명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Lair Noriega
회원 가입일: 04/04/22
237 평판
안내서 1개를 작성함
CSU Los Angeles, Team 4-84, Briggs Spring 2022 CSU Los Angeles, Team 4-84, Briggs Spring 2022 회원
CSULA-BRIGGS-S22S4G84
1 회원
안내서 2개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 46
지난 30일: 216
전체 시간: 5,278
