소개
The radio is one of the major features in a car that makes you more comfortable and entertained when out on rides. This guide will help you disassemble the radio within a 2008 Volkswagen Jetta and replace your broken one. This will require some previous experience with car work and very gentle care with removing plastic covers. This car is also foreign so be sure to have the right tools as Volkswagens tend to have more complex screws and screw-ins.
필요한 것
Starting from the back of the top panel, pry open the top panel with a panel tool.
Remove the top panel exposing the under.
There will be two clipped wires on the back of he radio.
Push the clips in on the black wires connected to loosen them up and carefully pull out the wire.
The second bunch of wires will only require a flip of the lever down on the bottom of the black outer box. Once flipped up remove the whole box to free the radio.
