주요 콘텐츠로 건너뛰기
2009-2019 Dodge Ram Fog Lights Replacement
필요한 것
  1. 2009-2019 Dodge Ram Fog Lights Replacement, Fog Lights: 1 단계, 이미지 1/1
    • Pull the hood latch that is located beneath the steering column.
  2. 2009-2019 Dodge Ram Fog Lights Replacement: 2 단계, 이미지 1/1
    • Push the lever to the left to unlatch the hood of the truck.
  3. 2009-2019 Dodge Ram Fog Lights Replacement: 3 단계, 이미지 1/1
    • Using the ratchet and 10mm socket, disconnect the negative battery terminal by turning counterclockwise.
    • This is done to make sure you do not get shortages.
  4. 2009-2019 Dodge Ram Fog Lights Replacement: 4 단계, 이미지 1/1
    • Disconnect the lighting harness.
    • Do not remove the bulb since the new fog lamp comes with integrated LED bulbs.
  5. 2009-2019 Dodge Ram Fog Lights Replacement: 5 단계, 이미지 1/1
    • Using the ratchet, extension, and the 10 mm socket unscrew the three 10 mm bolts to let the mounting plate free.
  6. 2009-2019 Dodge Ram Fog Lights Replacement: 6 단계, 이미지 1/2 2009-2019 Dodge Ram Fog Lights Replacement: 6 단계, 이미지 2/2
    • Push the tabs inward and pull the mounting bracket towards you to separate the bracket from the fog lamp.
  7. 2009-2019 Dodge Ram Fog Lights Replacement: 7 단계, 이미지 1/1
    • Grab the new fog lamp and insert the three clips into the three holes of the mounting bracket.
  8. 2009-2019 Dodge Ram Fog Lights Replacement: 8 단계, 이미지 1/2 2009-2019 Dodge Ram Fog Lights Replacement: 8 단계, 이미지 2/2
    • Align the three screw holes on the mounting bracket with the holes on the bumper.
  9. 2009-2019 Dodge Ram Fog Lights Replacement: 9 단계, 이미지 1/2 2009-2019 Dodge Ram Fog Lights Replacement: 9 단계, 이미지 2/2
    • Screw on the three 10 mm bolts in the holes.
    • Tighten the bolts by hand first.
    • Tighten the bolts using the 10 mm socket and ratchet.
  10. 2009-2019 Dodge Ram Fog Lights Replacement: 10 단계, 이미지 1/2 2009-2019 Dodge Ram Fog Lights Replacement: 10 단계, 이미지 2/2
    • Reconnect the lighting harness back up to get a power source.
  11. 2009-2019 Dodge Ram Fog Lights Replacement: 11 단계, 이미지 1/2 2009-2019 Dodge Ram Fog Lights Replacement: 11 단계, 이미지 2/2
    • Make sure the fog lamp is where it is desired and in place.
  12. 2009-2019 Dodge Ram Fog Lights Replacement: 12 단계, 이미지 1/1
    • Reconnect the negative battery terminal.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Omar Guerrero
회원 가입일: 09/25/21
232 평판
안내서 1개 작성함
University of Memphis, Team S50-G1, Willis Fall 2021 University of Memphis, Team S50-G1, Willis Fall 2021 회원
UM-WILLIS-F21S50G1
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 12
30일 전: 61
전체 시간: 2,061
