주요 콘텐츠로 건너뛰기
2009-2015 Suzuki Alto Head Unit Replacement
필요한 것
  1. 2009-2015 Suzuki Alto Head Unit Replacement, removing the bezels: 1 단계, 이미지 1/3 2009-2015 Suzuki Alto Head Unit Replacement, removing the bezels: 1 단계, 이미지 2/3 2009-2015 Suzuki Alto Head Unit Replacement, removing the bezels: 1 단계, 이미지 3/3
    • Use soft disassemble tools to remove the bezels hiding the screws.
  2. 2009-2015 Suzuki Alto Head Unit Replacement, removing the AC vents: 2 단계, 이미지 1/1
    • Pull it like a drawer.
  3. 2009-2015 Suzuki Alto Head Unit Replacement, remove the original head unit: 3 단계, 이미지 1/3 2009-2015 Suzuki Alto Head Unit Replacement, remove the original head unit: 3 단계, 이미지 2/3 2009-2015 Suzuki Alto Head Unit Replacement, remove the original head unit: 3 단계, 이미지 3/3
    • Disconnect the connectors.
  4. 2009-2015 Suzuki Alto Head Unit Replacement, removing the mounting plates: 4 단계, 이미지 1/2 2009-2015 Suzuki Alto Head Unit Replacement, removing the mounting plates: 4 단계, 이미지 2/2
    • Unscrew mounting plates from original headunit to custom headunit.
  5. 2009-2015 Suzuki Alto Head Unit Replacement, installing the mounting plates: 5 단계, 이미지 1/3 2009-2015 Suzuki Alto Head Unit Replacement, installing the mounting plates: 5 단계, 이미지 2/3 2009-2015 Suzuki Alto Head Unit Replacement, installing the mounting plates: 5 단계, 이미지 3/3
    • Screw the mounting plates on to your custom head unit.
    hi
    where do I get this bezel from?
    Gabriela Alejandra Agis - 답글
  6. 2009-2015 Suzuki Alto Head Unit Replacement, add the bezel: 6 단계, 이미지 1/3 2009-2015 Suzuki Alto Head Unit Replacement, add the bezel: 6 단계, 이미지 2/3 2009-2015 Suzuki Alto Head Unit Replacement, add the bezel: 6 단계, 이미지 3/3
    • Add the unit's bezel.
    Where do you get the bezel from ?
    fergusond007 - 답글
  7. 2009-2015 Suzuki Alto Head Unit Replacement, connecting the wires: 7 단계, 이미지 1/2 2009-2015 Suzuki Alto Head Unit Replacement, connecting the wires: 7 단계, 이미지 2/2
    • You will need an adapter from Suzuki's headunit connection to generic connection.
    whats is the name of the stock to generic adapter?
    zoharok - 답글
  8. 2009-2015 Suzuki Alto Head Unit Replacement, installing the headunit: 8 단계, 이미지 1/3 2009-2015 Suzuki Alto Head Unit Replacement, installing the headunit: 8 단계, 이미지 2/3 2009-2015 Suzuki Alto Head Unit Replacement, installing the headunit: 8 단계, 이미지 3/3
    • Return the AC grill, screws and bezels.
결승점
다른 18명이 해당 안내서를 완성하였습니다.
Jossef Harush
회원 가입일: 11/26/15
375 평판
안내서 1개 작성함
댓글 8개
Thanks for this, exactly what ive been looking for. I dont suppose you'd know the type of adapter necessary to connect the suzuki plug to an after market stereo? Thanks again for the guide!
robmatheson72 - 답글
Here is one sold under the type code CT20SZ02. Looks like this type of connector is used in a lot of recent Suzuki models, so they should be available from other stores (using other names).
knipwim -
Absolutely brilliant guide. Thanks. Had to purchase a different harness adaptor for my 14 alto sz3. It says on the packet the harness is for Honda Acc 9/98> but this fits and works 100%. Available from Halfords it is item PC2-68-4. Once again many thanks for the guide.
Bryan Tucker - 답글
Thanks Jossef Harush for such a detailed guide. It really helps me a lot but at last due to some reasons the connection cable tear out and I have to reach out Gomechanic team for the replacement with a genuine wire. Love their service as well as your guide too.
kasmira khandelwal - 답글
Thanks so much for this guide.
We have removed the screws on the head unit but it will not pull out at all, it seems completely stuck. Any suggestions on how to remove it or something we are missing?
James Insalaco - 답글
if you refer to the AC air vents then use more force, I’ve also experienced this.
Jossef Harush -
Hey guys, I am in need of the Brezel used in step 6. I reside in South Africa. Thank you for the guide, exactly what I needed.
MrTambi10 - 답글
can i fit any after market radio
Will Mcmanus - 답글
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 64
30일 전: 164
전체 시간: 16,631
