소개
The engine air filter should be replaced once every two years.
Follow this video tutorial by YouTuber NutzAboutBolts to complete the replacement yourself.
필요한 것
동영상 개요
Reinstall the air box by carefully sliding it back into position and securing it with the clips
Remember to always check your engine air filter when replacing it, and be mindful of your driving environment, as some areas may be dirtier or dustier than others
Regularly replacing your engine air filter can help maintain optimal engine performance and efficiency.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
What is above the air filter? It looks like another filter that has been glued to the housing right above the replaceable filter.ty
will scott - 답글
