주요 콘텐츠로 건너뛰기
2009-2014 Hyundai Sonata Cabin Air filter Replacement
  1. 2009-2014 Hyundai Sonata Cabin Air filter Replacement, Cabin Air filter Replacement  for. Hyundai Sonata: 1 단계, 이미지 1/1
    • Go to the passenger side of the car and sit in the passenger seat. Pull the glove box down using the lever.
  2. 2009-2014 Hyundai Sonata Cabin Air filter Replacement: 2 단계, 이미지 1/1
    • On the right side of the love box will be a plastic hydraulic; push the two pieces of plastic of the part sticking out towards each other. This should release the glove box on this side.
  3. 2009-2014 Hyundai Sonata Cabin Air filter Replacement: 3 단계, 이미지 1/1
    • Then on the top left, there is a plastic screw; unscrew it and be mindful that when this happens, the glove box will swing down.
  4. 2009-2014 Hyundai Sonata Cabin Air filter Replacement: 4 단계, 이미지 1/1
    • This is what the screw should look like after you take it out.
  5. 2009-2014 Hyundai Sonata Cabin Air filter Replacement: 5 단계, 이미지 1/1
    • This is what will be behind the glove box.
  6. 2009-2014 Hyundai Sonata Cabin Air filter Replacement: 6 단계, 이미지 1/1
    • On the right side there should be a clamp and push the two ends against each other and pull towards you.
  7. 2009-2014 Hyundai Sonata Cabin Air filter Replacement: 7 단계, 이미지 1/1
    • This is the clamp mentioned in the previous step.
  8. 2009-2014 Hyundai Sonata Cabin Air filter Replacement: 8 단계, 이미지 1/1
    • Then just pull the cover to the right to slide it out. Then you can access the air filter and change it from here.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Brandon Pollaccia
회원 가입일: 10/23/23
217 평판
안내서 1개 작성함
CSU Los Angeles, Team 5-19, Kershman Fall 2023 CSU Los Angeles, Team 5-19, Kershman Fall 2023 회원
CSULA-KERSHMAN-F23S5G19
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 23
30일 전: 92
전체 시간: 387
