소개
If the turn signal stops working in your 2013 KIA Soul, follow this guide to safely access and swap the lightbulb.
A working turn signal is an important feature of any car and can prevent accidents when driving. In addition, if your turn signal light is out, you may find yourself pulled over by the local police and ticketed.
Before you begin this guide, be sure that your car is off and in park, with the emergency brake on for extra safety.
When handling the new bulb, don't touch the glass with your bare hands as the oils on your fingers may can damage the glass and cause areas where heat may concentrate. This may significantly reduce the life of the bulb or it could shatter.
필요한 것
To access the battery and headlight, open the hood of the car.
Pull the lever near the foot pedals inside the car on the driver's side, to unlock the hood.
Use the hood lift support on the right side of the car to prop the hood open for repairs.
다른 한 분이 해당 안내서를 완성하였습니다.
