주요 콘텐츠로 건너뛰기
2009-2013 Mazda 3 Air Filter Replacement
필요한 것
  1. 2009-2013 Mazda 3 Air Filter Replacement, Air Filter: 1 단계, 이미지 1/1
    • Correctly identify the air filter for a 2009-2013 Mazda 3.
    • Go to your local car repair shop for help when buying the air filter.
  2. 2009-2013 Mazda 3 Air Filter Replacement: 2 단계, 이미지 1/1
    • Identify where the level is to pop the car hod.
  3. 2009-2013 Mazda 3 Air Filter Replacement: 3 단계, 이미지 1/1
    • After opening the hood, locate the air filter container.
    • It is located on the south side of the battery.
  4. 2009-2013 Mazda 3 Air Filter Replacement: 4 단계, 이미지 1/1
    • Identify where the metal clips are on the side of the air filter container.
    • Unlatch both metal clips on the air filter container to open.
  5. 2009-2013 Mazda 3 Air Filter Replacement: 5 단계, 이미지 1/1
    • When the air filter container is open, remove old filter.
    • When the old filter is removed, wipe out container with a wet paper towel.
    • Filter is in there tight, make sure to use a decent amount of force when pulling out.
  6. 2009-2013 Mazda 3 Air Filter Replacement: 6 단계, 이미지 1/1
    • Replace new filter.
    • It is a tight squeeze, so make sure the filter is properly fit into the container.
  7. 2009-2013 Mazda 3 Air Filter Replacement: 7 단계, 이미지 1/1
    • After you have replaced the new filter, close container and latch both metal hooks to close the container.
결론
You have successfully changed an air filter in any 2009-2013 Mazda 3 model.
다른 3명이 해당 안내서를 완성하였습니다.
Lana Sween
회원 가입일: 01/29/18
276 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 28
30일 전: 106
전체 시간: 2,372
