주요 콘텐츠로 건너뛰기
2009-2013 Mazda 3 Cabin Air Filter Replacement
필요한 것
  1. 2009-2013 Mazda 3 Cabin Air Filter Replacement, Cabin Air Filter: 1 단계, 이미지 1/1
    • Correctly identify and purchase the cabin air filter for your 2009-2013 Mazda 3 model.
    • If needed, visit your local car parts shop for help buying the cabin air filter.
  2. 2009-2013 Mazda 3 Cabin Air Filter Replacement: 2 단계, 이미지 1/3 2009-2013 Mazda 3 Cabin Air Filter Replacement: 2 단계, 이미지 2/3 2009-2013 Mazda 3 Cabin Air Filter Replacement: 2 단계, 이미지 3/3
    • Remove the panel under the middle console by pulling from the bottom and then from the top.
    • It is on the passenger side of your vehicle.
  3. 2009-2013 Mazda 3 Cabin Air Filter Replacement: 3 단계, 이미지 1/2 2009-2013 Mazda 3 Cabin Air Filter Replacement: 3 단계, 이미지 2/2
    • Remove the black panel under the passenger-side dashboard by unclipping the two tabs,
    • Unclip by pushing on the tabs.
  4. 2009-2013 Mazda 3 Cabin Air Filter Replacement: 4 단계, 이미지 1/3 2009-2013 Mazda 3 Cabin Air Filter Replacement: 4 단계, 이미지 2/3 2009-2013 Mazda 3 Cabin Air Filter Replacement: 4 단계, 이미지 3/3
    • Remove the two 2 mm Phillips screws securing the bottom of the filter housing.
    • Pull the tab at the top of the housing cover to remove it.
    • Handle filter housing parts gently.
  5. 2009-2013 Mazda 3 Cabin Air Filter Replacement: 5 단계, 이미지 1/1
    • Pull out one of the two air filters.
    • The second filter, located on top of first filter, should fall into the same place as you remove the first one.
    • If the second filter doesn't fall, reach it and gently remove it.
  6. 2009-2013 Mazda 3 Cabin Air Filter Replacement: 6 단계, 이미지 1/2 2009-2013 Mazda 3 Cabin Air Filter Replacement: 6 단계, 이미지 2/2
    • Insert the new filters into the slots.
    • The wide side of the air filter goes last.
    • Position the first filter on top.
    • The first filter should fit and stay on top. It might take a few tries.
    • Ensure the second air filter fits tightly underneath the one on top.
  7. 2009-2013 Mazda 3 Cabin Air Filter Replacement: 7 단계, 이미지 1/1
    • Place the housing cover back in position.
    • Tighten the two screws to secure the cover.
  8. 2009-2013 Mazda 3 Cabin Air Filter Replacement: 8 단계, 이미지 1/2 2009-2013 Mazda 3 Cabin Air Filter Replacement: 8 단계, 이미지 2/2
    • Position the black panel under the passenger side dashboard.
    • Clip the two tabs back into place by pushing on them to secure the panel.
    • Align the side panel back under the middle console.
    • Secure the panel by pushing it back into place from the top and the bottom.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Ovi Ahmed
회원 가입일: 10/24/23
178 평판
안내서 1개 작성함
CSU Los Angeles, Team 8-2, Ribeiro Fall 2023 CSU Los Angeles, Team 8-2, Ribeiro Fall 2023 회원
CSULA-RIBEIRO-F23S8G2
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 24
7일 전: 122
30일 전: 535
전체 시간: 2,400
