주요 콘텐츠로 건너뛰기
2009 Ducati Hypermotard 1100 Oil Replacement
필요한 것
  1. 2009 Ducati Hypermotard 1100 Oil Replacement, Motor Oil: 1 단계, 이미지 1/2 2009 Ducati Hypermotard 1100 Oil Replacement, Motor Oil: 1 단계, 이미지 2/2
    • First, place a small bucket right below the hexagonal socket that is located under the motorcycle.
  2. 2009 Ducati Hypermotard 1100 Oil Replacement: 2 단계, 이미지 1/2 2009 Ducati Hypermotard 1100 Oil Replacement: 2 단계, 이미지 2/2
    • Next, remove the drainage bolt with the 3/8 Allen wrench.
    • Twist the bolt clockwise until it is loose enough to twist off with your fingers.
    • Remember to be careful when removing the bolt because the oil could potentially be hot if the motorcycle was turned on before.
  3. 2009 Ducati Hypermotard 1100 Oil Replacement: 3 단계, 이미지 1/2 2009 Ducati Hypermotard 1100 Oil Replacement: 3 단계, 이미지 2/2
    • Once the drainage bolt has been removed, place it to the side and wait for the old oil to drain out.
    • When the oil is just about done draining, tilt the motorcycle left and right to make sure all the oil is out of the engine as shown in the second image.
  4. 2009 Ducati Hypermotard 1100 Oil Replacement: 4 단계, 이미지 1/3 2009 Ducati Hypermotard 1100 Oil Replacement: 4 단계, 이미지 2/3 2009 Ducati Hypermotard 1100 Oil Replacement: 4 단계, 이미지 3/3
    • After your old oil has drained completely; remove the oil cap by twisting clockwise with your hands as shown in the second image.
    • Next, insert the funnel into the engine as shown in the image.
  5. 2009 Ducati Hypermotard 1100 Oil Replacement: 5 단계, 이미지 1/1
    • Pour in about 0.5 quart of oil into the funnel and let it drain out in order to wash out the old oil.
    • This step should be performed before you replace the drainage bolt.
  6. 2009 Ducati Hypermotard 1100 Oil Replacement: 6 단계, 이미지 1/1
    • Clean your drainage bolt and wipe off all the excess oil before putting it back on underneath the motorcycle.
  7. 2009 Ducati Hypermotard 1100 Oil Replacement: 7 단계, 이미지 1/2 2009 Ducati Hypermotard 1100 Oil Replacement: 7 단계, 이미지 2/2
    • Replace the drainage bolt with your hands.
    • When you cannot tighten it anymore manually; tighten it with your 3/8 Allen wrench.
  8. 2009 Ducati Hypermotard 1100 Oil Replacement: 8 단계, 이미지 1/1
    • Pour in the new oil into the motorcycle.
    • This particular motorcycle only needs 3.5 quarts of 10W-40 motor oil (about 3 and half quarts bottles). Do not go over, or under the required amount or it can cause problems with your engine.
  9. 2009 Ducati Hypermotard 1100 Oil Replacement: 9 단계, 이미지 1/1
    • Screw the oil cap back on tight using your hands.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Oscar Baron
회원 가입일: 10/11/20
228 평판
안내서 1개 작성함
댓글 한 개
Finally it's fixed
Nicoletta - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 81
전체 시간: 2,264
