소개
The door handle of a vehicle is prone to degrade overtime. This guide will help you with the car door replacement of a 2009 Kia Sorento. The tools used were a flat head screwdriver and socket wrench with a 10mm attachment.
필요한 것
Before you can start removing the side panel, the speaker on the driver side door must be removed. To do this, simply squeeze and it will pop out. There is a little wire that connects the speaker to the car. To detach it there is a little button that can be pushed and it will come loose.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 2개
I got up to "remove the white blocks (electrical) from the door panel". I couldn't get them out. Any suggestions?
I'm about to do this 2009 Kia Sorento LX both driver and passenger front handle replacement next weekend. I hope yours went well, wish me luck!!
MoniB -
