주요 콘텐츠로 건너뛰기
2009 Subaru Impreza WRX Front Door Panel Replacement
필요한 것
  1. 2009 Subaru Impreza WRX Front Door Panel Replacement, Front Door Panel: 1 단계, 이미지 1/2 2009 Subaru Impreza WRX Front Door Panel Replacement, Front Door Panel: 1 단계, 이미지 2/2
    • Pry up the plastic tab from inside the handle located on the front door armrest.
  2. 2009 Subaru Impreza WRX Front Door Panel Replacement: 2 단계, 이미지 1/1
    • Pry up the plastic tab from inside the door handle housing.
  3. 2009 Subaru Impreza WRX Front Door Panel Replacement: 3 단계, 이미지 1/2 2009 Subaru Impreza WRX Front Door Panel Replacement: 3 단계, 이미지 2/2
    • Use your Phillips screwdriver to unscrew the 8x3/4" Phillips screw by the upper door handle.
    • Unscrew the second 8x3/4" Phillips screw located inside the lower door handle on the door's armrest.
  4. 2009 Subaru Impreza WRX Front Door Panel Replacement: 4 단계, 이미지 1/2 2009 Subaru Impreza WRX Front Door Panel Replacement: 4 단계, 이미지 2/2
    • Pry off the entire door speaker and its housing located inside of the mirror.
    • Using your flathead screwdriver, pry up the latch connecting the two white cords and disconnect the speaker.
  5. 2009 Subaru Impreza WRX Front Door Panel Replacement: 5 단계, 이미지 1/2 2009 Subaru Impreza WRX Front Door Panel Replacement: 5 단계, 이미지 2/2
    • Using your flathead screwdriver, pry the middle plastic door piece away from the armrest.
  6. 2009 Subaru Impreza WRX Front Door Panel Replacement: 6 단계, 이미지 1/2 2009 Subaru Impreza WRX Front Door Panel Replacement: 6 단계, 이미지 2/2
    • Using your flathead screwdriver, press the white tab on the side of the larger cord bundle connecting the assembly.
    • The larger cord bundle now can be pulled out.
    • Press the white tab on the smaller cord bundle and disconnect the smaller cord bundle from the assembly.
    • Take note of the two screws that are now visible in the middle of the door panel.
  7. 2009 Subaru Impreza WRX Front Door Panel Replacement: 7 단계, 이미지 1/2 2009 Subaru Impreza WRX Front Door Panel Replacement: 7 단계, 이미지 2/2
    • Unscrew both 8x3/4" Phillips screws from the middle of the door panel using your Phillips screwdriver.
  8. 2009 Subaru Impreza WRX Front Door Panel Replacement: 8 단계, 이미지 1/2 2009 Subaru Impreza WRX Front Door Panel Replacement: 8 단계, 이미지 2/2
    • Pry the left side of the door panel away from the door using a flathead screwdriver.
    • It may be easiest to start by prying away where the red circle is located.
  9. 2009 Subaru Impreza WRX Front Door Panel Replacement: 9 단계, 이미지 1/2 2009 Subaru Impreza WRX Front Door Panel Replacement: 9 단계, 이미지 2/2
    • Using your hands now, pry the door panel away from the door.
    • You will hear a series of pops when the white tabs disconnect from the door.
  10. 2009 Subaru Impreza WRX Front Door Panel Replacement: 10 단계, 이미지 1/2 2009 Subaru Impreza WRX Front Door Panel Replacement: 10 단계, 이미지 2/2
    • Finish pulling the door off of the frame, now that all the clips have been disconnected.
    • Pull the door from the top, not the bottom or sides.
  11. 2009 Subaru Impreza WRX Front Door Panel Replacement: 11 단계, 이미지 1/1
    • Disconnect the final two power window cables that connect the door panel to the door frame by pulling both out of their sockets.
    • Congratulations! You are now done.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Alex Spady
회원 가입일: 05/01/15
180 평판
안내서 1개 작성함
Cal Poly, Team 8-3, Regan Spring 2015 Cal Poly, Team 8-3, Regan Spring 2015 회원
CPSU-REGAN-S15S8G3
5 회원들
안내서 5개 작성하였습니다
댓글 한 개
Do you know if the elbow pad can be replaced by itself or does the whole panel need to be replaced?
J B - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 24
전체 시간: 2,681
