주요 콘텐츠로 건너뛰기
2009 Subaru Impreza WRX Front Speaker Replacement
필요한 것
  1. 2009 Subaru Impreza WRX Front Speaker Replacement, Front Door Panel: 1 단계, 이미지 1/2 2009 Subaru Impreza WRX Front Speaker Replacement, Front Door Panel: 1 단계, 이미지 2/2
    • Pry up the plastic tab from inside the handle located on the front door armrest.
  2. 2009 Subaru Impreza WRX Front Speaker Replacement: 2 단계, 이미지 1/1
    • Pry up the plastic tab from inside the door handle housing.
  3. 2009 Subaru Impreza WRX Front Speaker Replacement: 3 단계, 이미지 1/2 2009 Subaru Impreza WRX Front Speaker Replacement: 3 단계, 이미지 2/2
    • Use your Phillips screwdriver to unscrew the 8x3/4" Phillips screw by the upper door handle.
    • Unscrew the second 8x3/4" Phillips screw located inside the lower door handle on the door's armrest.
  4. 2009 Subaru Impreza WRX Front Speaker Replacement: 4 단계, 이미지 1/2 2009 Subaru Impreza WRX Front Speaker Replacement: 4 단계, 이미지 2/2
    • Pry off the entire door speaker and its housing located inside of the mirror.
    • Using your flathead screwdriver, pry up the latch connecting the two white cords and disconnect the speaker.
  5. 2009 Subaru Impreza WRX Front Speaker Replacement: 5 단계, 이미지 1/2 2009 Subaru Impreza WRX Front Speaker Replacement: 5 단계, 이미지 2/2
    • Using your flathead screwdriver, pry the middle plastic door piece away from the armrest.
  6. 2009 Subaru Impreza WRX Front Speaker Replacement: 6 단계, 이미지 1/2 2009 Subaru Impreza WRX Front Speaker Replacement: 6 단계, 이미지 2/2
    • Using your flathead screwdriver, press the white tab on the side of the larger cord bundle connecting the assembly.
    • The larger cord bundle now can be pulled out.
    • Press the white tab on the smaller cord bundle and disconnect the smaller cord bundle from the assembly.
    • Take note of the two screws that are now visible in the middle of the door panel.
  7. 2009 Subaru Impreza WRX Front Speaker Replacement: 7 단계, 이미지 1/2 2009 Subaru Impreza WRX Front Speaker Replacement: 7 단계, 이미지 2/2
    • Unscrew both 8x3/4" Phillips screws from the middle of the door panel using your Phillips screwdriver.
  8. 2009 Subaru Impreza WRX Front Speaker Replacement: 8 단계, 이미지 1/2 2009 Subaru Impreza WRX Front Speaker Replacement: 8 단계, 이미지 2/2
    • Pry the left side of the door panel away from the door using a flathead screwdriver.
    • It may be easiest to start by prying away where the red circle is located.
  9. 2009 Subaru Impreza WRX Front Speaker Replacement: 9 단계, 이미지 1/2 2009 Subaru Impreza WRX Front Speaker Replacement: 9 단계, 이미지 2/2
    • Using your hands now, pry the door panel away from the door.
    • You will hear a series of pops when the white tabs disconnect from the door.
  10. 2009 Subaru Impreza WRX Front Speaker Replacement: 10 단계, 이미지 1/2 2009 Subaru Impreza WRX Front Speaker Replacement: 10 단계, 이미지 2/2
    • Finish pulling the door off of the frame, now that all the clips have been disconnected.
    • Pull the door from the top, not the bottom or sides.
  11. 2009 Subaru Impreza WRX Front Speaker Replacement: 11 단계, 이미지 1/1
    • Disconnect the final two power window cables that connect the door panel to the door frame by pulling both out of their sockets.
    • Congratulations! You are now done.
  12. 2009 Subaru Impreza WRX Front Speaker Replacement, Front Speaker: 12 단계, 이미지 1/1
    • This is how the speaker will look when the inside of the door is removed (refer to front door removal guide for more info).
  13. 2009 Subaru Impreza WRX Front Speaker Replacement: 13 단계, 이미지 1/2 2009 Subaru Impreza WRX Front Speaker Replacement: 13 단계, 이미지 2/2
    • There will be three 8x3/4" Phillips screws (the third screw is indicated by the arrow; you can't see the screw in the picture) keeping the speaker in place. Use a #0 Phillips screwdriver to remove them.
  14. 2009 Subaru Impreza WRX Front Speaker Replacement: 14 단계, 이미지 1/2 2009 Subaru Impreza WRX Front Speaker Replacement: 14 단계, 이미지 2/2
    • There will be a plastic adapter connecting wires to the speaker. To separate the adapter from the speaker, use a flathead screwdriver or spudger to pry the adapter off.
  15. 2009 Subaru Impreza WRX Front Speaker Replacement: 15 단계, 이미지 1/1
    • Remove the plastic adapter from the wiring using wire cutters as shown.
  16. 2009 Subaru Impreza WRX Front Speaker Replacement: 16 단계, 이미지 1/2 2009 Subaru Impreza WRX Front Speaker Replacement: 16 단계, 이미지 2/2
    • Using wire strippers, strip the two wires shown (blue and white, respectively) at about 1 inch from the end.
  17. 2009 Subaru Impreza WRX Front Speaker Replacement: 17 단계, 이미지 1/2 2009 Subaru Impreza WRX Front Speaker Replacement: 17 단계, 이미지 2/2
    • Using pliers, attach a special adapter piece to both wires as shown. Simply insert the wire into the plastic cavity and apply pressure.
  18. 2009 Subaru Impreza WRX Front Speaker Replacement: 18 단계, 이미지 1/3 2009 Subaru Impreza WRX Front Speaker Replacement: 18 단계, 이미지 2/3 2009 Subaru Impreza WRX Front Speaker Replacement: 18 단계, 이미지 3/3
    • Locate the part of your new speaker which has two 8x3/4" Phillips screws in line. Unscrew these screws slightly to allow the adapter pieces to fit under them, then screw them back in to secure the wires.
    • Make sure the wiring connector is fully tightened under screw.
  19. 2009 Subaru Impreza WRX Front Speaker Replacement: 19 단계, 이미지 1/2 2009 Subaru Impreza WRX Front Speaker Replacement: 19 단계, 이미지 2/2
    • The final step is to place the new speaker, and tighten the same three screws as before to secure it.
    • If you're having problems with your new speaker, refer to the troubleshooting guide here.
결론
Jared Spadaro
회원 가입일: 05/01/15
125 평판
안내서 1개 작성함
Cal Poly, Team 8-3, Regan Spring 2015 Cal Poly, Team 8-3, Regan Spring 2015 회원
CPSU-REGAN-S15S8G3
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 17
전체 시간: 4,844
