주요 콘텐츠로 건너뛰기
2009 Subaru Impreza WRX Rear Door Panel Replacement
필요한 것
  1. 2009 Subaru Impreza WRX Rear Door Panel Replacement, Rear Door Panel: 1 단계, 이미지 1/1
    • Pry off the plastic tab inside the rear door handle.
  2. 2009 Subaru Impreza WRX Rear Door Panel Replacement: 2 단계, 이미지 1/1
    • Use the Phillips screwdriver to unscrew the 8x3/4" Phillips screw inside the door handle.
  3. 2009 Subaru Impreza WRX Rear Door Panel Replacement: 3 단계, 이미지 1/1
    • Use a flathead screwdriver to pry up the plastic tab inside the rear door armrest.
  4. 2009 Subaru Impreza WRX Rear Door Panel Replacement: 4 단계, 이미지 1/1
    • Use the Phillips screwdriver to unscrew the 8x3/4" Phillips screw inside the armrest.
  5. 2009 Subaru Impreza WRX Rear Door Panel Replacement: 5 단계, 이미지 1/2 2009 Subaru Impreza WRX Rear Door Panel Replacement: 5 단계, 이미지 2/2
    • Use flathead to pry off the upper panel located at the top of the rear door panel.
  6. 2009 Subaru Impreza WRX Rear Door Panel Replacement: 6 단계, 이미지 1/2 2009 Subaru Impreza WRX Rear Door Panel Replacement: 6 단계, 이미지 2/2
    • Use the flathead screwdriver to pry off and remove the panel over the door handle.
  7. 2009 Subaru Impreza WRX Rear Door Panel Replacement: 7 단계, 이미지 1/1
    • Remove the bundle of wires from the panel by pressing the tabs on the sides of the large white plastic connector.
  8. 2009 Subaru Impreza WRX Rear Door Panel Replacement: 8 단계, 이미지 1/1
    • Use the Phillips screwdriver to unscrew the 8x3/4" screws behind the door handle panel that was just removed.
  9. 2009 Subaru Impreza WRX Rear Door Panel Replacement: 9 단계, 이미지 1/1
    • Use the flathead screwdriver to pry off the door panel, starting from the outside edge of the door.
  10. 2009 Subaru Impreza WRX Rear Door Panel Replacement: 10 단계, 이미지 1/1
    • Use your hands to pull off and remove the door panel from the frame.
  11. 2009 Subaru Impreza WRX Rear Door Panel Replacement: 11 단계, 이미지 1/1
    • Using your hands, remove the two remaining wires connecting the door panel to the frame.
    • The door panel is now completely removed from the frame.
결론
Joseph Coplon
회원 가입일: 04/20/15
101 평판
안내서 1개 작성함
Cal Poly, Team 8-3, Regan Spring 2015 Cal Poly, Team 8-3, Regan Spring 2015 회원
CPSU-REGAN-S15S8G3
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 13
전체 시간: 2,435
