주요 콘텐츠로 건너뛰기
2009 Toyota Corolla Headlight Bulb Replacement
필요한 것
  1. 2009 Toyota Corolla Headlight Bulb Replacement, Headlight Bulb: 1 단계, 이미지 3개 중 1개 2009 Toyota Corolla Headlight Bulb Replacement, Headlight Bulb: 1 단계, 이미지 3개 중 2개 2009 Toyota Corolla Headlight Bulb Replacement, Headlight Bulb: 1 단계, 이미지 3개 중 3개
    • Wear gloves to avoid getting hands covered in engine grease.
    • Unlock the hood of the car by pulling the release located at the bottom-left side of the steering wheel.
    • Make sure to watch your hands for certain hazards, parts of the car may be sharp or hazardous.
  2. 2009 Toyota Corolla Headlight Bulb Replacement: 2 단계, 이미지 3개 중 1개 2009 Toyota Corolla Headlight Bulb Replacement: 2 단계, 이미지 3개 중 2개 2009 Toyota Corolla Headlight Bulb Replacement: 2 단계, 이미지 3개 중 3개
    • Open the hood and lock it in place.
    • Find the bulb near the inside of where the headlight is on the car (it should be located somewhere within the red circle). It will be attached to a wire.
    • Rotate the bulb until it becomes free and pull it out of the headlight casing.
  3. 2009 Toyota Corolla Headlight Bulb Replacement: 3 단계, 이미지 2개 중 1개 2009 Toyota Corolla Headlight Bulb Replacement: 3 단계, 이미지 2개 중 2개
    • Press and hold the button illustrated in the photo and pull the bulb apart from the wire. If the button is jammed, a screw driver may be necessary to press the button down with more force.
    • Be careful not to snap the bulb part from the connector when working to pull it out of the cable.
    • By now, the bulb should be separate from its container.
  4. 2009 Toyota Corolla Headlight Bulb Replacement: 4 단계, 이미지 1개 중 1개
    • Replace old bulb with new one by simply sliding it back onto the cable.
  5. 2009 Toyota Corolla Headlight Bulb Replacement: 5 단계, 이미지 1개 중 1개
    • Install the new bulb back into the headlight casing by turning clockwise until it is firmly connected as shown in the picture. Close the hood of the car.
    • Remember to realign the grooves on the bulb to match the connection with the headlight casing.
  6. 2009 Toyota Corolla Headlight Bulb Replacement: 6 단계, 이미지 1개 중 1개
    • Turn the car on and test your new headlight!
    • If the headlight doesn't work, turn car off and ensure the connection is correct with the headlight cable.
결론
작성자
2다른 기여자 명과 함께
Talha
회원 가입일: 04/16/24
133 평판
안내서 1개를 작성함
York University, Team 1-2, Morris Winter 2024 York University, Team 1-2, Morris Winter 2024 회원
YORK-MORRIS-W24S1G2
5 회원들
안내서 2개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 23
지난 30일: 92
전체 시간: 604
