주요 콘텐츠로 건너뛰기
2010-Present Subaru Legacy Rear Door Reassembly
  1. 2010-Present Subaru Legacy Rear Door Reassembly, 2010-Present Subaru Legacy Rear Door Reassembly: 1 단계, 이미지 1/3 2010-Present Subaru Legacy Rear Door Reassembly, 2010-Present Subaru Legacy Rear Door Reassembly: 1 단계, 이미지 2/3 2010-Present Subaru Legacy Rear Door Reassembly, 2010-Present Subaru Legacy Rear Door Reassembly: 1 단계, 이미지 3/3
    • Insert the metal ball into the plastic door pull handle assembly.
    • With the ball inserted, route the steel cable through the assembly and align the black plastic notch on the cable with the plastic notch on the door pull handle assembly.
    • Press the cable notch into the door pull handle notch and snap it into place.
  2. 2010-Present Subaru Legacy Rear Door Reassembly: 2 단계, 이미지 1/1
    • Hold the door lock in the "unlocked" position with your thumb. This will make it easier to insert the metal ball into the door lock assembly.
  3. 2010-Present Subaru Legacy Rear Door Reassembly: 3 단계, 이미지 1/2 2010-Present Subaru Legacy Rear Door Reassembly: 3 단계, 이미지 2/2
    • Insert the metal ball into the plastic door lock assembly.
    • With the ball inserted, route the steel cable through the assembly and align the blue plastic notch on the cable with the plastic notch on the door lock assembly.
    • Press the cable notch into the door lock notch and snap it into place.
결론
Miroslav Djuric
158,326 평판
안내서 144개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 9
전체 시간: 697
