주요 콘텐츠로 건너뛰기
2010-2017 Suzuki Swift Engine Air Filter Replacement
필요한 것
  1. 2010-2017 Suzuki Swift Engine Air Filter Replacement, locate the filter: 1 단계, 이미지 1/3 2010-2017 Suzuki Swift Engine Air Filter Replacement, locate the filter: 1 단계, 이미지 2/3 2010-2017 Suzuki Swift Engine Air Filter Replacement, locate the filter: 1 단계, 이미지 3/3
    • The filter housing is located behind the air intake.
    • Pull both clasps holding the filter housing to the air intake.
    • Push the housing back to see the filter.
  2. 2010-2017 Suzuki Swift Engine Air Filter Replacement, remove old filter: 2 단계, 이미지 1/2 2010-2017 Suzuki Swift Engine Air Filter Replacement, remove old filter: 2 단계, 이미지 2/2
    • Slide the old filter up and out.
    • Remember the only square corner of the filter is in the left bottom side.
    • Clean the immediate area of the filter housing, to make sure no dirt ends up in the engine.
  3. 2010-2017 Suzuki Swift Engine Air Filter Replacement, add new filter: 3 단계, 이미지 1/1
    • With the square corner at the correct position, slide the new filter in.
    • Make sure the filter fits up with the backside of the air intake on all sides.
  4. 2010-2017 Suzuki Swift Engine Air Filter Replacement, close the filter housing: 4 단계, 이미지 1/2 2010-2017 Suzuki Swift Engine Air Filter Replacement, close the filter housing: 4 단계, 이미지 2/2
    • Underneath the air filter, 2 holes have to line up with plugs on the filter housing.
    • Once the underside is connected correctly, a small plastic protrustion has to line up with a corresponding guide on the air intake.
    • Clip back the 2 clips, and you are done.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
knipwim
회원 가입일: 09/01/18
8,527 평판
안내서 30개 작성하였습니다
댓글 한 개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 26
30일 전: 137
전체 시간: 6,437
