주요 콘텐츠로 건너뛰기
2010-2017 Suzuki Swift Tail Light Bulb Replacement
필요한 것
  1. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, loosen the tail light: 1 단계, 이미지 1/3 2010-2017 Suzuki Swift Tail Light Bulb Replacement, loosen the tail light: 1 단계, 이미지 2/3 2010-2017 Suzuki Swift Tail Light Bulb Replacement, loosen the tail light: 1 단계, 이미지 3/3
    • Unscrew the two visible bolts.
    • After unscrewing the bolts, the other side of the light is still fastened by two clickable plugs.
    • Using the panel removal tool, pry behind each corner and unclick each plug.
  2. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, access backside of the light: 2 단계, 이미지 1/1
    • Remove the light from the frame and place it on the tailgate.
    • You might need to remove some of the cabling from cable guides.
    • You can also better see the plugs that held the light in place.
  3. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, remove the fitting: 3 단계, 이미지 1/1
    • Unscrew the fitting about 45 degrees and lift it from the casing.
  4. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, replace the bulb: 4 단계, 이미지 1/2 2010-2017 Suzuki Swift Tail Light Bulb Replacement, replace the bulb: 4 단계, 이미지 2/2
    • Remove the bulb by turning it about 45 degrees.
    • And do the reverse with the new bulb, push and turn.
    • The bulb has 2 guide pins assuring a correct install.
    • The fitting has 2 corresponding receivers.
  5. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, insert fitting: 5 단계, 이미지 1/1
    • Insert the fitting by matching up the fitting guides with their openings on the casing and turn it 45 degrees clockwise.
  6. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, put the light back: 6 단계, 이미지 1/1
    • Tuck back any cables you loosened, and place the light back on the car frame.
    • Make sure the replaced light actually works.
    • Push the light plugs back in.
    • Put the 2 screws back in.
    • You are done.
결승점
다른 5명이 해당 안내서를 완성하였습니다.
knipwim
회원 가입일: 09/01/18
8,527 평판
안내서 30개 작성하였습니다
댓글 한 개
댓글 쓰기
조회 통계:
24 시간 전: 12
7일 전: 111
30일 전: 446
전체 시간: 35,237
