주요 콘텐츠로 건너뛰기
2010-2014 BMW X6 Tail Light Bulb Replacement
  1. 2010-2014 BMW X6 Tail Light Bulb Replacement, Tail Light Bulb: 1 단계, 이미지 1/1
    • Turn off the car and let the car cool down for 5 minutes.
  2. 2010-2014 BMW X6 Tail Light Bulb Replacement: 2 단계, 이미지 1/2 2010-2014 BMW X6 Tail Light Bulb Replacement: 2 단계, 이미지 2/2
    • Open the trunk using your key in the trunk key slot or by using the button under the CD player.
  3. 2010-2014 BMW X6 Tail Light Bulb Replacement: 3 단계, 이미지 1/3 2010-2014 BMW X6 Tail Light Bulb Replacement: 3 단계, 이미지 2/3 2010-2014 BMW X6 Tail Light Bulb Replacement: 3 단계, 이미지 3/3
    • Remove the small plastic cover along the vertical edge of the trunk entrance by pulling outwards using the handle.
    • Pull outwards till pannel comes off and place down giving access to the inside of the quarter panel.
  4. 2010-2014 BMW X6 Tail Light Bulb Replacement: 4 단계, 이미지 1/3 2010-2014 BMW X6 Tail Light Bulb Replacement: 4 단계, 이미지 2/3 2010-2014 BMW X6 Tail Light Bulb Replacement: 4 단계, 이미지 3/3
    • Grab the light bulb socket and turn it counterclockwise until it can be removed from its hole.
    • Repeat this process for the other light bulb socket.
  5. 2010-2014 BMW X6 Tail Light Bulb Replacement: 5 단계, 이미지 1/1
    • Remove the light bulbs from their sockets by gently pulling them away from the connectors.
  6. 2010-2014 BMW X6 Tail Light Bulb Replacement: 6 단계, 이미지 1/3 2010-2014 BMW X6 Tail Light Bulb Replacement: 6 단계, 이미지 2/3 2010-2014 BMW X6 Tail Light Bulb Replacement: 6 단계, 이미지 3/3
    • Place the new bulb in the original hole.
    • Turn clockwise to secure the bulb in place.
  7. 2010-2014 BMW X6 Tail Light Bulb Replacement: 7 단계, 이미지 1/2 2010-2014 BMW X6 Tail Light Bulb Replacement: 7 단계, 이미지 2/2
    • Place Plastic cover along the bottom of the trunk next to the corresponding hole.
    • Push cover in till it is flush with a vertical wall of the trunk.
  8. 2010-2014 BMW X6 Tail Light Bulb Replacement: 8 단계, 이미지 1/2 2010-2014 BMW X6 Tail Light Bulb Replacement: 8 단계, 이미지 2/2
    • Close trunk and admire your hard work!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Juan M Perez
회원 가입일: 10/05/21
190 평판
안내서 1개 작성함
CSU Los Angeles, Team 11-99, Grodsky Fall 2021 CSU Los Angeles, Team 11-99, Grodsky Fall 2021 회원
CSULA-GRODSKY-F21S11G99
1 회원
안내서 1개 작성하였습니다
댓글 한 개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 16
30일 전: 81
전체 시간: 2,245
