주요 콘텐츠로 건너뛰기
2010-2014 Ford Mustang Air Filter Replacement
  1. 2010-2014 Ford Mustang Air Filter Replacement, Air Filter: 1 단계, 이미지 1/2 2010-2014 Ford Mustang Air Filter Replacement, Air Filter: 1 단계, 이미지 2/2
    • Make sure the vehicle is off before proceeding. Working under the cars hood can lead to burns if the car is still hot. Be careful!
    • Open the hood by pulling on the lever by the driver's feet.
    • Push upward on the latch under the center of the hood to unlock it.
  2. 2010-2014 Ford Mustang Air Filter Replacement: 2 단계, 이미지 1/1
    • Locate the Air Box
  3. 2010-2014 Ford Mustang Air Filter Replacement: 3 단계, 이미지 1/3 2010-2014 Ford Mustang Air Filter Replacement: 3 단계, 이미지 2/3 2010-2014 Ford Mustang Air Filter Replacement: 3 단계, 이미지 3/3
    • Locate the two latches that keep the air box closed.
    • Push on the latch to open the air box as shown in the picture, and repeat on the second latch.
    • Pull up on the top part of the air box and push it to the front of the car to open.
  4. 2010-2014 Ford Mustang Air Filter Replacement: 4 단계, 이미지 1/2 2010-2014 Ford Mustang Air Filter Replacement: 4 단계, 이미지 2/2
    • Make note of the orientation of the air filter before removing it.
    • Lift the filter straight up from the triangle corner and remove it.
  5. 2010-2014 Ford Mustang Air Filter Replacement: 5 단계, 이미지 1/2 2010-2014 Ford Mustang Air Filter Replacement: 5 단계, 이미지 2/2
    • Inspect for debris and dirt.
    • The first filter is dirty but does not need to be cleaned or replaced yet.
    • The second filter is dirty and does need to be cleaned or replaced
    • Do not discard the filter because it may be covered under a warranty.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Christopher Pell
회원 가입일: 09/26/12
251 평판
안내서 5개 작성하였습니다
Cal Poly, Team 15-45, Forte Fall 2012 Cal Poly, Team 15-45, Forte Fall 2012 회원
CPSU-FORTE-F12S15G45
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 35
전체 시간: 4,809
