주요 콘텐츠로 건너뛰기
2010-2014 Ford Mustang Fuses Replacement
필요한 것
  1. 2010-2014 Ford Mustang Fuses Replacement, Blown Fuse Replacement: 1 단계, 이미지 1/2 2010-2014 Ford Mustang Fuses Replacement, Blown Fuse Replacement: 1 단계, 이미지 2/2
    • Turn off the vehicle before beginning the fuse changing process to avoid electrocution.
    • Pull the hood release lever near the drivers feet to release the hood.
    • Move to the front of the vehicle.
    • Push the latch below the center of the hood to the left to unlock and open the hood.
    • Lift the hood and support it with the hood strut.
  2. 2010-2014 Ford Mustang Fuses Replacement: 2 단계, 이미지 1/1
    • The fuse box is located on the drivers side of the vehicle. It is a black rectangular box.
    • Open the fuse box by disengaging the latch on the left side of the fuse box by flipping it upwards or to the right.
  3. 2010-2014 Ford Mustang Fuses Replacement: 3 단계, 이미지 1/1
    • Referencing the Fuse Box Diagram, identify the blown fuse that needs replacement.
  4. 2010-2014 Ford Mustang Fuses Replacement: 4 단계, 이미지 1/2 2010-2014 Ford Mustang Fuses Replacement: 4 단계, 이미지 2/2
    • Remove the fuse that correspondences to the electrical failure in the vehicle by carefully pulling the fuse straight up and out of the fuse box.
    • It is safe to do this with your hands, just move slowly and carefully as you remove the blown fuse.
    • Check for damage or discoloration in the fuse.
    • Replace the damaged fuse with the new fuse by pushing it back into the appropriate fuse port. The new fuse should sit flush with the other fuses and may click when inserted correctly.
    • Close the fuse box and fasten latch on left side of fuse box.
결론
To reassemble, follow these instructions in reverse order.
Christopher Pell
회원 가입일: 09/26/12
251 평판
안내서 5개 작성하였습니다
Cal Poly, Team 15-45, Forte Fall 2012 Cal Poly, Team 15-45, Forte Fall 2012 회원
CPSU-FORTE-F12S15G45
5 회원들
안내서 6개 작성하였습니다
댓글 한 개
The fuse is stuck. How do I get it out.
Delia Gress - 답글
댓글 쓰기
조회 통계:
24 시간 전: 15
7일 전: 96
30일 전: 480
전체 시간: 18,720
