주요 콘텐츠로 건너뛰기
2010-2014 Ford Mustang Spark Plug Replacement
필요한 것
  1. 2010-2014 Ford Mustang Spark Plug Replacement, Spark Plug: 1 단계, 이미지 1/1
    • Open the hood and prop it open using the hood prop.
  2. 2010-2014 Ford Mustang Spark Plug Replacement: 2 단계, 이미지 1/1
    • Pull the red tab out of the electrical connector and slide the connector off of the coil pack.
  3. 2010-2014 Ford Mustang Spark Plug Replacement: 3 단계, 이미지 1/1
    • Remove the 10mm screw from the coil pack. Use the 10mm socket on the 3/8" drive ratchet to remove the screw.
  4. 2010-2014 Ford Mustang Spark Plug Replacement: 4 단계, 이미지 1/1
    • Remove the coil pack from cylinder.
  5. 2010-2014 Ford Mustang Spark Plug Replacement: 5 단계, 이미지 1/1
    • Loosen the spark plug completely using the 3/8" ratchet and extension with the 5/8" spark plug socket.
  6. 2010-2014 Ford Mustang Spark Plug Replacement: 6 단계, 이미지 1/1
    • Remove the spark plug from the cylinder using the grabber tool.
  7. 2010-2014 Ford Mustang Spark Plug Replacement: 7 단계, 이미지 1/1
    • Inspect the spark plug for blackening or other damage.
  8. 2010-2014 Ford Mustang Spark Plug Replacement: 8 단계, 이미지 1/1
    • Check the spark plug gap using the spark plug gap gauge. Make sure the gap is within desired specifications.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Alyssa Walser
회원 가입일: 10/07/19
184 평판
안내서 1개 작성함
댓글 4개
its a 9/16 socket for plugs for 3v heads( 05-10 mustangs gts) other than that great guide
CarGuy1991 - 답글
“To reassemble your device, follow these instructions in reverse order”
-_-
Wil Xavier - 답글
What about right bank, you have to take off the plemum should you disconnect the neg on battery before you restart the engine??
John - 답글
I agree. You have a whole lot more to do on the left side. You may even need new gaskets. May not be difficult but will take some time. Right side is easy peasy.
Lyndon “L J” J - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 19
30일 전: 134
전체 시간: 10,186
