주요 콘텐츠로 건너뛰기
2010-2014 Ford Mustang Wheel Replacement
필요한 것
  1. 2010-2014 Ford Mustang Wheel Replacement, Wheel: 1 단계, 이미지 1/1
    • Read over the guidelines for safety reasons before you begin.
    • Place the hydraulic jack under the metal frame of the car near the tire that you want to change.
    • Consult the car owner's manual for exact locations to place the hydraulic jack.
  2. 2010-2014 Ford Mustang Wheel Replacement: 2 단계, 이미지 1/3 2010-2014 Ford Mustang Wheel Replacement: 2 단계, 이미지 2/3 2010-2014 Ford Mustang Wheel Replacement: 2 단계, 이미지 3/3
    • Cars are very heavy and can pose danger when they are elevated by the car jack. Exercise caution around the elevated vehicle.
    • Crack the bolts loose before raising the car
    • Pump the jack handle evenly until the tire raises only an inch or two off of the ground. Be sure not to lay underneath the vehicle until the new wheel is properly installed.
  3. 2010-2014 Ford Mustang Wheel Replacement: 3 단계, 이미지 1/1
    • Lug nuts hold the wheel in place. Use the 13/16" socket with a breaker bar to remove the lug nuts by turning the nuts counterclockwise.
    • Store the lug nuts in a safe place so that you do not lose them.
  4. 2010-2014 Ford Mustang Wheel Replacement: 4 단계, 이미지 1/1
    • The wheel will be heavy. You should brace yourself to bear the weight. Seek help if the wheel is too heavy for you.
    • Grab the wheel with both hands and pull the wheel straight off and away from the car.
    • Do not risk dropping the wheel onto the brake rotor, which would cause damage to it.
  5. 2010-2014 Ford Mustang Wheel Replacement: 5 단계, 이미지 1/1
    • Place a new wheel on the hub, and then fix it in place by tightening the lug nuts clockwise. In other words, skip every other nut as you go around the wheel.
    • Lower the car after snugging the bolts then torque the wheel nuts to 100ftlb
    to keep from damaging rims and rotors be sure to torque the bolts to the proper torque 100 ft-lb
    Ross - 답글
결론
Follow these instructions in reverse order to reassemble the wheel back to the vehicle.
다른 5명이 해당 안내서를 완성하였습니다.
Christopher Pell
회원 가입일: 09/26/12
251 평판
안내서 5개 작성하였습니다
Cal Poly, Team 15-45, Forte Fall 2012 Cal Poly, Team 15-45, Forte Fall 2012 회원
CPSU-FORTE-F12S15G45
5 회원들
안내서 6개 작성하였습니다
댓글 한 개
I have found it to be better to loosen the wheel nuts before you jack up the car. Also, when replacing the wheel nuts, these must be torqued to the proper value. This requires the use of a torque wrench. Consult your manual for the proper torque on the wheel nuts.
Dave Bassett - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 15
전체 시간: 7,128
