소개
Use this guide to help you replace a cracked, chipped, or worn-out seal for the windshield. This replacement is for the following vehicles: 2005 - 2013 BMW 335i or E92 series. Replacing this requires some tools, but it is relatively simple.
필요한 것
Please begin using a 90-degree pick and lift the seal from the top corner (either side is fine).
Use both your hands and the tool to slowly lift up the seal.
이 단계에 사용된 도구:Microfiber Cleaning Cloths$3.99
Grab your favorite all-purpose cleaner or any degreaser, and make sure to spray directly into all the crevices.
You will also need a microfiber towel to clean the crevices; if they are too tight, please use the 90-degree pick to get in between all the cracks.
I want to mention that the rear glass seal takes the same steps as the windshield seal. Please follow the steps carefully.
