소개
The following guide will walk through steps necessary to replace headlights on a 2010 Chevrolet Aveo and all similar model years. You may find it necessary to complete this replacement if you have noticed your headlight dimming after many years of use. This guide will help to replace these dim headlights so you remain safe on the road. This replacement is accomplished by removing the headlight housing from the vehicle for ease of access.
필요한 것
Repeat steps 3 through 9 for other headlight. Ensure proper working order upon completion.
다른 4명이 해당 안내서를 완성하였습니다.
