주요 콘텐츠로 건너뛰기
2010 GMC Sierra Tail Light Replacement
필요한 것
  1. 2010 GMC Sierra Tail Light Replacement, Tail Light: 1 단계, 이미지 1/3 2010 GMC Sierra Tail Light Replacement, Tail Light: 1 단계, 이미지 2/3 2010 GMC Sierra Tail Light Replacement, Tail Light: 1 단계, 이미지 3/3
    • Open the hood of the truck.
    • Using the 10mm wrench, loosen and remove the 1-3/4" bolt securing the cable.
    • Pull the cable from the battery.
  2. 2010 GMC Sierra Tail Light Replacement: 2 단계, 이미지 1/2 2010 GMC Sierra Tail Light Replacement: 2 단계, 이미지 2/2
    • Lower the tail gate fully.
    • Remove objects near tail light.
  3. 2010 GMC Sierra Tail Light Replacement: 3 단계, 이미지 1/2 2010 GMC Sierra Tail Light Replacement: 3 단계, 이미지 2/2
    • Using the Philips screwdriver, remove the two 4.8x16mm screws securing the housing.
  4. 2010 GMC Sierra Tail Light Replacement: 4 단계, 이미지 1/2 2010 GMC Sierra Tail Light Replacement: 4 단계, 이미지 2/2
    • Pry the housing free.
    • Be mindful of wires and dust.
  5. 2010 GMC Sierra Tail Light Replacement: 5 단계, 이미지 1/2 2010 GMC Sierra Tail Light Replacement: 5 단계, 이미지 2/2
    • Rotate the harness counterclockwise.
    • Pull the harness free from the housing.
  6. 2010 GMC Sierra Tail Light Replacement: 6 단계, 이미지 1/2 2010 GMC Sierra Tail Light Replacement: 6 단계, 이미지 2/2
    • Wearing the latex gloves, pull the bad bulb out of the harness.
    • Skin oil shortens the bulbs' life spans.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Charles Swain
회원 가입일: 06/19/19
142 평판
안내서 1개 작성함
University of Memphis, Team S1-G4, Lane Summer 2019 University of Memphis, Team S1-G4, Lane Summer 2019 회원
UM-LANE-SU19S1G4
3 회원들
안내서 1개 작성하였습니다
댓글 한 개
Is there a way to get these things not to get moisture inside the backup bulb area?
ron murphy - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 14
전체 시간: 1,798
