주요 콘텐츠로 건너뛰기
2010 Jeep Liberty Headlight Bulb Replacement
필요한 것
  1. 2010 Jeep Liberty Headlight Bulb Replacement, Headlight Bulb: 1 단계, 이미지 1/1
    • Pop the hood of your vehicle by pulling the lever near the bottom of the driver's side door.
    • Slide your hands under the unlatched hood to find the second lever. Push this lever to the right and lift the hood.
    • Be sure to use the hood prop to keep the hood from falling while you're underneath it.
  2. 2010 Jeep Liberty Headlight Bulb Replacement: 2 단계, 이미지 1/3 2010 Jeep Liberty Headlight Bulb Replacement: 2 단계, 이미지 2/3 2010 Jeep Liberty Headlight Bulb Replacement: 2 단계, 이미지 3/3
    • Identify the bulb socket, located behind the headlight.
    • Rotate the base of the bulb counter-clockwise to remove it from the socket.
    • Remove the bulb from the green base by pulling the two apart.
  3. 2010 Jeep Liberty Headlight Bulb Replacement: 3 단계, 이미지 1/3 2010 Jeep Liberty Headlight Bulb Replacement: 3 단계, 이미지 2/3 2010 Jeep Liberty Headlight Bulb Replacement: 3 단계, 이미지 3/3
    • Insert the new bulb into the green base.
    • Be sure not to touch the glass with your fingers. If you do, wipe the bulb down with a soft cloth and some rubbing alcohol. Oils left behind from your fingers can shorten the life of the bulb.
    • Rotate clockwise to lock the bulb assembly into the socket.
  4. 2010 Jeep Liberty Headlight Bulb Replacement: 4 단계, 이미지 1/1
    • Turn on headlights to ensure the new bulb is working properly.
    • You will want to check that your headlights are aligned on both sides. Adjust as needed.
결론
Congratulations! You have a shiny new headlight.
다른 8명이 해당 안내서를 완성하였습니다.
Ryan Griffin
회원 가입일: 01/19/16
245 평판
안내서 1개 작성함
Oakland University, Team 6-1, Walwema Winter 2016 Oakland University, Team 6-1, Walwema Winter 2016 회원
OAK-WALWEMA-W16S6G1
10 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 13
30일 전: 46
전체 시간: 8,952
