소개
Replacing LED unit in BMW wing mirrors which functions as an 'auxiliary' turn signal (in addition to the main indicator lamps).
필요한 것
Gently use a car trim tool to pop the mirror glass off its central holder. You shouldn't need to detach the cables to it, as it can just rest against the window after removal.
거의 끝나갑니다!
To reassemble, follow these instructions in reverse order.
결론
다른 2명이 해당 안내서를 완성하였습니다.
