주요 콘텐츠로 건너뛰기
2011-2017 Hyundai Accent Brake Light Replacement
  1. 2011-2017 Hyundai Accent Brake Light Replacement, Brake Light: 1 단계, 이미지 1/1
    • Open the trunk of the vehicle.
  2. 2011-2017 Hyundai Accent Brake Light Replacement: 2 단계, 이미지 1/3 2011-2017 Hyundai Accent Brake Light Replacement: 2 단계, 이미지 2/3 2011-2017 Hyundai Accent Brake Light Replacement: 2 단계, 이미지 3/3
    • View the side flap for whichever side has the dead bulb. (This is the left side view.)
    • Pull the flap up and locate the brake light.
    • The flap may need some extra force to open because the cutouts are typically not cut all the way through.
  3. 2011-2017 Hyundai Accent Brake Light Replacement: 3 단계, 이미지 1/2 2011-2017 Hyundai Accent Brake Light Replacement: 3 단계, 이미지 2/2
    • Twist the socket counterclockwise to gain access to the brake light.
  4. 2011-2017 Hyundai Accent Brake Light Replacement: 4 단계, 이미지 1/2 2011-2017 Hyundai Accent Brake Light Replacement: 4 단계, 이미지 2/2
    • Push down slightly and twist the bulb counterclockwise to remove the dead bulb.
    • Pay attention to the protrusions located on the bottom of the bulb. You will need to align these protrusions with the socket when inserting the new bulb.
  5. 2011-2017 Hyundai Accent Brake Light Replacement: 5 단계, 이미지 1/2 2011-2017 Hyundai Accent Brake Light Replacement: 5 단계, 이미지 2/2
    • Insert the new bulb into the socket and twist the bulb clockwise to secure it into place.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Brianna Pegues
회원 가입일: 03/04/21
202 평판
안내서 1개 작성함
댓글 한 개
When I followed the instructions in reverse order as instructed to reassemble everything, I ended up with the old bulb back in the vehicle. Is there any way to fix this?
The Other Guy - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 55
30일 전: 308
전체 시간: 14,096
