소개
If your 2013 Hyundai Accent brake light is no longer working, use this guide to replace the light.
The brake light alerts other drivers of whether you are slowing down or stopping the vehicle. It is important to ensure that you have a working brake light because it is a ticketable offense and for safety reasons.
Before using this guide, make sure to turn the car off and to purchase a replacement bulb (Model: Sylvania 2357LL).
다른 3명이 해당 안내서를 완성하였습니다.
댓글 한 개
When I followed the instructions in reverse order as instructed to reassemble everything, I ended up with the old bulb back in the vehicle. Is there any way to fix this?
