소개
This guide will help you replace the air filter on your 2011-2014 Dodge Challenger 3.6L V6 by locating the air filter housing, using a screwdriver or clips to open it, removing the old filter, cleaning the housing if necessary, inserting the new filter with the correct orientation, sealing the housing securely, and checking for a snug fit. Don't forget to dispose of the old filter and record the replacement date.
필요한 것
Pop The Engine Hood Open
Reminder- Hood Latch Release is Under the Steering Wheel
Now you Have Completely Replaced Your car's Engine Air Filter.
다른 한 분이 해당 안내서를 완성하였습니다.
