주요 콘텐츠로 건너뛰기
2011-2013 Scion tC Car Battery Replacement
필요한 것
  1. 2011-2013 Scion tC Car Battery Replacement, Car Battery: 1 단계, 이미지 1/1
    • Begin by opening the hood of the car and locating the battery on the front of the driver side in the engine compartment
  2. 2011-2013 Scion tC Car Battery Replacement: 2 단계, 이미지 1/1
    • Using a socket wrench, loosen the 2 (5/16 inch) nuts on the top of the battery support bracket
    • Remove the bracket by lifting up
  3. 2011-2013 Scion tC Car Battery Replacement: 3 단계, 이미지 1/1
    • After removing the bracket, locate the supporting rod behind the battery
    • The rod is hooked on a hole in the metal behind the battery. Unhook the rod and remove it
  4. 2011-2013 Scion tC Car Battery Replacement: 4 단계, 이미지 1/2 2011-2013 Scion tC Car Battery Replacement: 4 단계, 이미지 2/2
    • Start with the negative terminal of the battery
    • Loosen the nut on the negative terminal with a 10mm socket wrench
    • Remove the wire by slightly twisting and pulling up
  5. 2011-2013 Scion tC Car Battery Replacement: 5 단계, 이미지 1/2 2011-2013 Scion tC Car Battery Replacement: 5 단계, 이미지 2/2
    • Remove the cap from the positive terminal of the battery
    • Using a 10mm socket wrench, loosen the nut on the positive terminal
    • Remove the wire from the positive terminal by slightly twisting and pulling up
    • Remove the battery by lifting it out of the engine compartment
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Travis Michael
회원 가입일: 05/08/15
140 평판
안내서 1개 작성함
Cal Poly, Team 8-2, Regan Spring 2015 Cal Poly, Team 8-2, Regan Spring 2015 회원
CPSU-REGAN-S15S8G2
5 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 14
30일 전: 46
전체 시간: 10,726
