주요 콘텐츠로 건너뛰기
2011-2013 Scion tC Radio Head Unit Replacement
필요한 것
  1. 2011-2013 Scion tC Radio Head Unit Replacement, Radio Head Unit: 1 단계, 이미지 1/2 2011-2013 Scion tC Radio Head Unit Replacement, Radio Head Unit: 1 단계, 이미지 2/2
    • Remove the dashboard panel around the radio head by pulling on the bottom of the unit.
  2. 2011-2013 Scion tC Radio Head Unit Replacement: 2 단계, 이미지 1/2 2011-2013 Scion tC Radio Head Unit Replacement: 2 단계, 이미지 2/2
    • Remove the wire header connected to the panel by pressing inward on the tabs.
  3. 2011-2013 Scion tC Radio Head Unit Replacement: 3 단계, 이미지 1/1
    • Remove the four #2 12mm screws securing the head unit in the housing
  4. 2011-2013 Scion tC Radio Head Unit Replacement: 4 단계, 이미지 1/2 2011-2013 Scion tC Radio Head Unit Replacement: 4 단계, 이미지 2/2
    • Remove each bundle of wires that is connected to the back of the head unit.
  5. 2011-2013 Scion tC Radio Head Unit Replacement: 5 단계, 이미지 1/2 2011-2013 Scion tC Radio Head Unit Replacement: 5 단계, 이미지 2/2
    • Locate the metal brackets on the side of the head unit.
    • Use a Philips head screwdriver, remove the three #2 25mm screws from both support brackets on the side of the head unit
  6. 2011-2013 Scion tC Radio Head Unit Replacement: 6 단계, 이미지 1/1
    • Screw the support brackets to the new radio head unit
    • Note that the brackets are unique to the car. They will not come with your new head unit.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Dylan Smith
회원 가입일: 05/01/15
143 평판
안내서 1개 작성함
Cal Poly, Team 8-2, Regan Spring 2015 Cal Poly, Team 8-2, Regan Spring 2015 회원
CPSU-REGAN-S15S8G2
5 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 17
30일 전: 38
전체 시간: 7,452
